Where to buy oil filter + crush gasket
I need a filter and crush gasket/washer for my first DIY oil change. I've found a few places to buy online but shipping doubles the cost of the filter. Can quality oil filters and a crush ring be purchased from CDN Tire or PartSource? The PartSource rep couldn't tell me what gasket I needed, but they carry Mann oil filters for ~$15 (opinions on this brand?)
Mann used to be OEM not sure if they are now. There have been many makers of this filter over the years for Porsche. The O ring (you call it a gasket) should be inside the box with the filter. FYI: Roll this O ring over the threads of the plastic filter housing - NOT stretching it over the threads, (and a light coating of engine oil on it). There are two grooves that this O ring 'could' fit into - the groove closest to the threads on the filter housing is the one you want. If you get this wrong and pop it into the next (second one) groove - you'll leak oil all over town until you correct this oversight. Ask me how I know this... ![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
The crush ring is usually taped to the top of the box for your oil drain bolt (hex key), (18ft pounds torque). I buy my filters from indy's out here in the west end. I'd go back to PartSourse and ask to look inside the box to see if the O ring is inside. You can use the crush able oil drain washer again in an emergency (not optimum) but the torque settings are a little higher I've read if you do. I've seen two types - a copper type and a nickel type. I don't know why the change in material - probably cost.
Thanks for the info, always good to hear what to avoid based on other's unfortunate circumstances ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
By crush gasket I was referring to the drain plug gasket, I looked at the Mann filter today and saw the large O-ring taped inside... but the crush ring for the drain plug is where I'm lost. I was under the assumption this needed to be changed every time the oil was changed. You're saying it should be included in the drain plug box with makes me think I'm supposed to change the drain plug with every oil change also? I must be misunderstanding something
But in an *emergency you can use it again (such as the time I go to use the new one and couldn't find it! Can't put oil back in without it on the bolt/ can't drive anywhere without oil!)
Make sure your pan is large enough for the drain - our cars have more oil in them then the Exxon Valdez... I re-cycle my oil through Mississauga's waste transfer stations where it's free to bring your old oil in.
