Shockingly unprofessional service at Indies in Toronto and Calgary
Email me for details, and protect yourself, this is my first P-car, two weeks in, and I am shocked at some of the misses and conduct at these two "reputable" shops that "everyone" uses!
Had a PPI done at indi in Tornto. No brake issues identified. Car purchased and brought to Calgary, failed provincial safety inspection at Calgary indi. Front rotors below 30mm spec and parking brakes burned off. My bill today was $1800. I emailed T indi last week and asked what his thoughts are and if he used a "different criteria" (giving him benefit of the doubt). No response from T indi. I am shocked that brakes were missed after I paid him for a good PPI. My car has been stuck in the shop waiting for parts and not able to register in Alberta until work is completed.
On top of that, Calgary indi heard me mention that I think the windscreen is leaking, but I said I will wait to look into it. While it is waiting for brakes, they went ahead and removed the windscreen at the glass shop next door without any authorization from me. (“We thought you wanted that taken care of”). Then they said there is no OEM glass for five working days (think you would have checked first?). And they are using a “good window” guy next door that they like, but I would never have selected. So now, waiting for rubber seals (maybe tomorrow). The window came in ($1100 quote installed). So I was forced to make my first windscreen claim on insurance already, one week into ownership. I went down and they had the car sitting without glass 10 yards from a freight train running by behind the shop. You can imagine what I said.
So I might get the car done and on the road tomorrow. And so far super unimpressed by the indies. I am def doing DIY whenever possible.
Call the Toronto shop on the phone. And PM me the name if you would -- not that I can do anything for you, as I tend to avoid confrontation, but I would like to know who it is.
Also, ask to see all the old parts the Calgary shop removed. Take them with you in a box when you leave the shop.
Captain Obvious
Super User
Super User
Also, make sure that parts they give you back are from your car. Till you can personally check the Calgary shop's claims, this is nothing more than one shop blaming the other to get you to pay.
Are you sure about the rotor width as I thought 30mm would be new. I just had a PPI done at Weissach in Vancouver and they use 26mm as the min before change (on a 996 anyway) - they're a very reputable shop!!
Here is the exact email quote from Calg indi: "The park brake shoes linings are burnt off and the front brake discs are below the 30mm minimum thickness". I viewed the new rotors, and they have a stamp on the edge "30mm min". Apparently they are 32mm new, so I was surprised at the tiny 1mm (40 thou) per side allowable wear.
+1 it may save a few board members hassle and expense done the road.
Captain Obvious
Super User
Super User
I'm not trying to protect the shop, just pointing out how things can be missed or missleading, even if the shop is good.
Team Owner
Sounds to me the Calgary shop is taking you for I ride looking for as much as they can. If the shop pills on the pb lever and it doesn't roll it will pass. I think the shop did you a favor. Charging you Labour to pull the rotors off that may have been bonded on along with calipers when the car ipb feels fine would have been more annoying to me.
That saw an opportunity to replace the shoes while in there ripping you off on your other brakes.
I really only see very minor issues with the TO shop.
Btw I don't use any shop. You are obviously very upset so I am just trying to provide unbiased opinion only.
Welcome aboard
Welcome aboard
