Activate DRL on US specs boxster?
Old 04-11-2012, 10:44 PM
mrhulala
mrhulala's Avatar
Default Activate DRL on US specs boxster?
I'm getting a 09 US spec boxster, anyone knows where I can get the DRL activated? I heard Paff would charge $1500, any other options for me? DIY possible?
Any comment is appreciated!!
Old 04-11-2012, 10:54 PM
Zookie
Zookie's Avatar
call EU Autowerks...
Old 04-12-2012, 12:27 AM
Christien
Christien's Avatar
$75 at mantis for a 986 boxster. Can't imagine it could be that much more for a 987. Even if it's double, that's a tenth of the dealer charge.
Old 04-12-2012, 12:45 AM
Jaak Lepson
Rest In Peace Jaak
Cable Guy
Jaak Lepson's Avatar
Try this ... http://911car.blogspot.ca/2009/05/da...k-986-996.html
Daytime Running Lights DRL Hack 986 996
In Canada there is a traffic law, for every single car on the road it must have daytime running lights, basically headlights on at all times day or night, many have imported US Spec Porsches into Canada and in order to pass a Federal Inspection they needed to have Daytime Running Lights installed, they visited their friendly local Porsche Dealers and then got hammered with couple hundred dollars fees for a relay installation and a couple of electrical wiring, I heard of people paying $400-$500 I was stunned. For those of you who are planning on importing a US Spec Porsche 986 Boxster or 996 Carrera in Canada or for anyone wanting to have Daytime Running Lights there is a simple hack that will cost you a couple dollars at most $10. I picked up this hack a couple years back on a website can't remember where but clearly remember how it's done.
Locate the fuse box cover on the lower left side underneath the dash, remove the cover and locate fuse number A6 and A9, both fuses are located on the first top row, from left to right fuse #6 and fuse #9, if you don’t have heated seats the #6 fuse slot will be empty, once located you will need to have a 3 inch long electrical wire (18 gauge wire is good) strip each end of the wire approx ½” on each end of the wire, what you need to do is use that 3” wire to jump fuse #6 and #9 like a bridge, take one end of the wire and wrap it around one peg of the fuse and the other end on one peg of the other fuse and insert both fuse back into slot #6 and #9 , if you had an empty slot, simply use a spare fuse on the empty slot. Verify that the hack worked by putting the ignition key on the headlights should come on. This hack is an easy one and it could save you hundreds of dollars.
Old 04-12-2012, 08:58 AM
Mike_UCR
Mike_UCR's Avatar
I used the 6-9 fuse hack on my US spec 996. Works like a charm and only took 10 minutes and $.50 of wire.
Old 04-12-2012, 09:00 AM
theiceman
Team Owner
theiceman's Avatar
Received 1,024 Likes on 728 Posts
^ this ....
Old 04-12-2012, 10:31 AM
Speedyellow993
Speedyellow993's Avatar
A RL sells a Pre-made two fuse and a wire hack. All you need to do is plug it in. If I remember correctly it was $15.00
GL.
Old 04-12-2012, 11:03 AM
Christien
Christien's Avatar
Is the procedure the same for a 987 boxster? If it were my car, I'd want to know for sure before I buggered something up...
Old 04-12-2012, 11:10 AM
mrhulala
mrhulala's Avatar
Thanks for the info guys! Can anyone confirm fuse jump would work on 987.2 ?
Old 04-12-2012, 08:18 PM
acadian_dad
acadian_dad's Avatar
If you can, find someone with a Durametric Pro - will take about 30 sec to turn on DRL. If you are in Ottawa I can help you out. PM me.
Old 04-12-2012, 08:30 PM
Sultan
Sultan's Avatar
$10 hack vs. $1500 dealer charge....that is one hell of a markup and I'm sure the dealer is doing exactly the same thing.....
Old 04-13-2012, 12:13 AM
petee_c
petee_c's Avatar
Originally Posted by Mike_UCR
$.50 of wire.
You seriously overpaid for the wire.
I also did this hack to pass RIV when my 986S came up to Canada.....
I've seen removed it... might put it back on... we'll see.
P
Old 04-20-2012, 11:01 PM
mrhulala
mrhulala's Avatar
Thanks guys for replying!
I had it done at mantis for $100 today. But it looks a bit weird to me, see image attached. Now all 3 modes(Off, Home, Low beam) are acting exactly the same, which are having all lights on, and the side mark is always on at all 4 modes.
Is this the way it should be?
Old 04-21-2012, 09:57 PM
orangem
orangem's Avatar
My 987 is turned on by fiddling with the ECU. Yes, the headlight, markers are on all the time. The light switch only controls the dashboard lighting.....
Old 04-22-2012, 01:57 AM
carguy88
carguy88's Avatar
Agree that's how it should be - on my 986s all lights (except fog) are on whenever engine is running, light switch only controls interior lights as orangem said..
Quick Reply: Activate DRL on US specs boxster?
