Rennlist - Porsche Discussion Forums (https://rennlist.com/forums/)
-   Rennlist Canada (https://rennlist.com/forums/rennlist-canada-98/)
-   -   Jonathon's '82 911 SC Thread (https://rennlist.com/forums/rennlist-canada/685829-jonathons-82-911-sc-thread.html)
Jonathon Rolstin Mar 14, 2012 05:17 AM
Ok guys, I havn't had an official introduction yet so I figured I would write one up.
It all started when I was in University doing my undergrad. A friend of my dads asked me to come along to Mosport one weekend and I ended up getting my first pro-racing mechanics job with TRG.
https://forums.pelicanparts.com/uplo...1330913506.jpg
I worked off and on with them for a couple of years through 2007-2008 doing Grand-Am Koni Challenge stuff.
After that I got hooked up with GMG doing SCCA World Challenge GT and have been doing that ever since with a couple of short stints into ALMS and Patron GT3 Challenge.
https://forums.pelicanparts.com/uplo...1330913624.jpg
https://forums.pelicanparts.com/uplo...1330913636.jpg
https://forums.pelicanparts.com/uplo...1330913658.jpg
At the same time I kept really busy with school racing activities in Formula SAE. I ran the powertrain department during my time there.
Here is a shot of our F2008. I'm on the right. This was after coming 2nd place to UofT at a technical design presentation made by myself and my friend Steve. (We were a startup team, so to come 2nd to a team like UofT was a great finish for us.)
https://forums.pelicanparts.com/uplo...1330913739.jpg
Here is a shot with my Dad at Mosport during an FSAE Shootout.
https://forums.pelicanparts.com/uplo...1330913848.jpg
Some action shots of me throwing down some flyers at Mosport.
https://forums.pelicanparts.com/uplo...1330913891.jpg
https://forums.pelicanparts.com/uplo...1330913914.jpg
And finally, I poured my heart and soul into this one. The aerodynamics was my thesis project and was dynamically adjustable in real time, independantly in all four corners.
https://forums.pelicanparts.com/uplo...1330913991.jpg
Then I graduate, and fastforward a little bit and I have my first house, am engaged to be married this august, am doing my masters part-time, started up my own regional Formula 1200 race team AVR Motorsports, and bought my first 911!
Jonathon Rolstin Mar 14, 2012 05:18 AM
A 1982 Porsche 911 SC
https://forums.pelicanparts.com/uplo...1330914110.jpg
First time home in our driveway and in front of the garage.
https://forums.pelicanparts.com/uplo...1330914173.jpg
I haven't really done much since I got it. I adjusted the valves without replacing the valve cover gaskets. It's a little bit leaky, and drips right on the exhaust - I had it on the DDT at Mosport and came off and the left heat exchanger was on fire. I put it out with a bottle of water but the engine is out to get cleaned up and resealed so that this doesn't happen again. I will also be doing caliper rebuilds and stainless line upgrade along with new pads and rotors.
Here is a picture with my dad pulling the motor for the first time! Thanks to his coworker Paul and my friend Matt for their hard work in helping to get it out that day... 8 hours, that with me already disconnecting most of everything needing disconnected...
https://forums.pelicanparts.com/uplo...1330914426.jpg
I have more photos to come as I have already seperated the trans, put the engine on the stand, started cleaning and disassembling! Stay tuned and I can't wait for the onslaught of opinions and comments!
Cheers
Jonathon Rolstin Mar 14, 2012 05:19 AM
Ok guys, High Res Pics!...
But here is the engine out on the jack stand with the transmission seperated.
https://forums.pelicanparts.com/uplo...1331082918.jpg
https://forums.pelicanparts.com/uplo...1331082974.jpg
On the stand CIS removed.
https://forums.pelicanparts.com/uplo...1331083125.jpg
Exhaust, fan and shroud removed.
https://forums.pelicanparts.com/uplo...1331083235.jpg
Some cleaning and removing engine mount bar.
https://forums.pelicanparts.com/uplo...1331083307.jpg
Other side.
https://forums.pelicanparts.com/uplo...1331083435.jpg
Some more cleaning.
https://forums.pelicanparts.com/uplo...1331083483.jpg
What the plugs look like...
https://forums.pelicanparts.com/uplo...1331083527.jpg
What the shop currently looks like, slightly cleaned trans in the foreground.
https://forums.pelicanparts.com/uplo...1331083568.jpg
And another view!
https://forums.pelicanparts.com/uplo...1331083623.jpg
As soon as I get some time back at home I will update these with high-res pics!
Cheers.
Alright so I promised some pics for the issues I am having... But I will start with a couple of new goodies I got!
A new vice... 5in, 80 bucks at Princess Auto.
https://forums.pelicanparts.com/uplo...1331086120.jpg
A 30 dollar bench grinder (6in) @ PA as well.
https://forums.pelicanparts.com/uplo...1331086170.jpg
Now my troubles... The dizzy connector, has anyone had this happen before? Ideas?
https://forums.pelicanparts.com/uplo...1331086237.jpg
I got a PM from a fellow Ontarian, Arthur, who said the drain plug was definitely 17mm - So I test fit it again... seemed ok...
https://forums.pelicanparts.com/uplo...1331086293.jpg
And out it came! The trans seems totally over-filled. I pulled the plug and it practically poured out from the top of the openning.
https://forums.pelicanparts.com/uplo...1331086375.jpg
Now the oil cooler... Here is the outside that was pried against.
https://forums.pelicanparts.com/uplo...1331086447.jpg
And the collapsed fins / semi-collapsed tube at one end...
https://forums.pelicanparts.com/uplo...1331086518.jpg
Thoughts?
Only had time to snap pics tonight...
Cheers.
Jonathon Rolstin Mar 14, 2012 05:20 AM
Hey guys, a little bit of an update here.
I took the valve covers off and have a couple of pictures.
https://forums.pelicanparts.com/uplo...1331220547.jpg
and the other side
https://forums.pelicanparts.com/uplo...1331220577.jpg
A have a couple questions here... look at where oil is getting... spark plug area... any ideas where this would be from? Rockers? Or the valve cover gaskets themselves?
Also, I checked torque on the head-studs... I found my loss of compression lol. They were loose, not scary loose, but quite loose. Anyways I am happy I caught it at a safe stage. I know the head studs were all replaced on this car a few thousand miles ago, so they mustn't have been re-torqued.
Next up, I removed, cleaned and resealed the crankcase breather cover, temp sender and pressure sender, oh and the pressure relief valve? The big round guy with the oring :P
https://forums.pelicanparts.com/uplo...1331220736.jpg
Another angle
https://forums.pelicanparts.com/uplo...1331220770.jpg
Pretty much all I could do in 3 hours today... When I removed my breather cover, one of the studs came out, so I cleaned it up, loctited it, and drove it back in. When I was ready to reinstall it I just removed the nut as the loctite had setup enough. I made sure to clean any that got on the mating surface with brake clean.
I also managed to check the torque on all my case perimeter nuts - I am happy to report none of them moved!
Ok so please reply with thoughts on the oil in the spark plug areas on the heads! I want to figure this one out, because I think this was seeping through the cam box mating surface and may be leading me to want to reseal the cam boxes when I really dont want to!
Cheers.
Jonathon Rolstin Mar 14, 2012 05:21 AM
I will start with some close ups of the rocker shafts...
https://forums.pelicanparts.com/uplo...1331300476.jpg
https://forums.pelicanparts.com/uplo...1331300513.jpg
https://forums.pelicanparts.com/uplo...1331300547.jpg
https://forums.pelicanparts.com/uplo...1331300590.jpg
https://forums.pelicanparts.com/uplo...1331300624.jpg
https://forums.pelicanparts.com/uplo...1331300697.jpg
https://forums.pelicanparts.com/uplo...1331300745.jpg
So, rocker shaft seals are definitely on the list. Now the dilemma is, I have been told these can be done without removing the camshaft housings. If that is true, great! Can some people chime in on this? It looks really dirty there and I almost want to pull them off just to give everything a really good cleaning. But also want to be on the road in a few weeks.
Also, some of the rocker shafts seem 'backed out', would this cause valvetrain noise? I am experiencing some on the 1-2-3 bank.
Another post to follow on my crank pulley progress!
Ok so good progress here, I had a low profile ratchet in my DD car tool kit and got the big plate off.
https://forums.pelicanparts.com/uplo...1331301035.jpg
https://forums.pelicanparts.com/uplo...1331301077.jpg
Dirty
https://forums.pelicanparts.com/uplo...1331301111.jpg
Failed seal!
https://forums.pelicanparts.com/uplo...1331301147.jpg
https://forums.pelicanparts.com/uplo...1331301205.jpg
Cleaned, and pry like this, but be gentle.
https://forums.pelicanparts.com/uplo...1331301272.jpg
And the other cover removed.
https://forums.pelicanparts.com/uplo...1331301310.jpg
Now you are probably asking yourself "what's his dilemma?" Well, I don't have any Curil-T Sealant. What could I use instead? Where can I get it in Canada? Should I install dry, or oiled around outter race? I know to oil the inner race... Can some experts help me out?
Cheers!
Jonathon Rolstin Mar 14, 2012 05:22 AM
So I was test fitting an allen wrench to start removing rockers... and the #3 shaft just slipped out as I was barely fitting the tool to it... found my valve-train tick... how did this not fail all summer!?!!!! Glad I decided to do this when I did....
https://forums.pelicanparts.com/uplo...1331668480.jpg
Here is a look at the light damage/scoring...
https://forums.pelicanparts.com/uplo...1331668518.jpg
Better view from the other side... :(
https://forums.pelicanparts.com/uplo...1331668542.jpg
#3 assembly...
https://forums.pelicanparts.com/uplo...1331668687.jpg
And my newest edition, 20gal parts washer :), took this shot freehand (tripod in picture) so it's a little blurry...
https://forums.pelicanparts.com/uplo...1331668729.jpg
So... I think I can get away with maybe a new shaft, bushing and hardware, because where it is warn, the shaft was out of adjustment by a few mm. Let me know what you guys think though. Looking for recommendations.
Cheers
For reference, this is what it looked like before I removed it.
https://forums.pelicanparts.com/uplo...1331670474.jpg
Jonathon Rolstin Mar 14, 2012 05:27 AM
This has been the last couple of weeks for me basically, I have been posting this on Pelican but wanted all my canadian buddies up to speed! I want to come out to the weekly get togethers this summer, but got to get this thing back together first!
Bergamasco Mar 14, 2012 09:05 AM
That is really cool. What a great story! If you are in the GTA and need a wedding photographer let me know. Congrats on your list of achievements and all the best for the upcoming race season.
jumper5836 Mar 14, 2012 09:13 AM
Looks like the 911 has a good home. Enjoy it!
Torontoworker Mar 14, 2012 10:07 AM
Great thread!
plumbum Mar 14, 2012 03:04 PM
Great thread! You make it look easy :)
porsche0nut Mar 14, 2012 08:17 PM
Welcome!! Fantastic introduction, I look forward to following this thread, great pics and writeup.
You and I are going to have to talk.... I'm also a Jonathan (spelled the proper way!), was on the UofT FSAE team '08-'10 while in Mech Eng, and am currently looking for an SC or 3.2!
Come out to the Saturday meets, would be fantastic to meet you and your car (when it's back together).
© 2026 MH Sub I, LLC dba Internet Brands
