NEED TO CHANGE THIS : HELP !
Hi
probably original parts
water infiltrates the car, doesn't fit tight on the window.
need to change on both sides.
any replacement suggestions ? they still make these ?
thanks
Luc
1978 sc targa
thanks
Luc
1978 sc targa
Luc that lookes like like the rear targa Bar seal ..it goes along the back of the roof and down. it then mate with the door seal at the bottom of the window . There were a couple of different styles and only one available now. You just cut it to fit if you need to.
As Christien saya they are available at Pelican . They can be very pricey so shop around. There are original genam and Cjinese . One guy put a CHinese one he payed a hundred dollars for but I have not heard how it is lasting.
If the back one is gone the front one is likely gone to. MAke sure you verify all your adjustments before buying new eals. I think I have your email so i will send you a doc on how to do that.
Good luck.
Good luck.
