Autocross tips
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
For all your experienced autocrossers out there I'm looking for any advice you can share from tire pressure to tips on how to win in the novice class, first time out tomorrow and I am super excited
Pressures will vary depending upon tires. Regular street tires should start in high 30psi range, perhaps 36 front, 38 rear cold. Decrease pressures back to this setting if they go up with heat after the ambient temperature goes up during the day or with competitive runs. You can also adjust to balance the car, decreasing pressure at the end that you want to stick more. IE, if understeering badly, lower the fronts.
"R" compound tires usually require less cold pressure.
Usual rookie mistakes are going too slowly in the fast sections and too fast in the slow sections. Hard to give specific pointers unless we know where you need improvements/advice.
BTW, being in Peterborough you are relatively close to my club's last slalom on the 16th, we're at Picton Airport. You are officially invited.
I think you have the pressure recommendation backwards?
TIRE PRESSURE
Guide To High Performance Handling
Adjustments
Decrease Understeer Decrease Oversteer
Front Tire Pressure Higher Lower
Rear Tire Pressure Lower Higher
Front Tire Section Larger Smaller
Rear Tire Section Smaller Larger
Front Wheel Camber More Negative More Positive
Rear Wheel Camber More Positive More Negative
Front Wheel Toe Toward Toe-Out Toward Toe-In
Rear Wheel Toe Toward Toe-In Toward Toe-Out
Front Wheel Caster More Positive More Negative
Front Springs Soften Stiffen
Rear Springs Stiffen Soften
Front Anti-sway Bar Soften (Thinner) Stiffen (Thicken)
Rear Anti-sway Bar Stiffen (Thicker) Soften (Thinner)
Weight Distribution More Rearward More Forward
TIRE PRESSURE
Adjustments
Basically, if you go too high, you lose traction, if you go too low, you lose traction.
Setup and fine tuning of the car are very secondary at this point anyway. The best thing to do is work on the nut behind the wheel and learn to drive well. Get pointers and go for rides with experienced drivers. Don't develop bad habits and don't mess with the car unless you need to.
Really I should have left it out as the "rules" are too general. Which end you decrease/increase pressure at to balance depends on many factors such as which end of the car is heavier, what tires, what nominal pressures, tire size, rain, etc.
