Cleaning Sooty Tail Pipes ... products
Has anybody tried any of these products to break through the black carbon crap on tailpipes?
Busch Aluminum Polish "Super Shine"
http://www.eshine.ca/busch_aluminum_...701.php?cat=16
P21S Polishing Soap
http://www.eshine.ca/p21s_polishing_...708.php?cat=16
I've used Wenol Red with limited success.
http://www.eshine.ca/original_wenol_red-3252.php?cat=16
P21S Polishing Soap
i have tired quite a few polishies and they have al yeild all the same results... im using Chemical Guys Metal Shine right now... Eshine swears by Busch. I just ordered some P21S Soap, really want to try this out. If it works teh same im going to thorw eveything out and just use the saop and i really cant tell the diffrence in the results...
None of the automotive products worked for me. The only thing that has worked is Barkeepers Friend which is available at Williams Sonoma (I used it as a last ditch effort because it works so well on cast cookware). I wouldn't have the guts to use it on chrome thought because I think there's a mild abrasive. I made a soup out of it with water and it worked well. Hope that helps.
P21S Polishing Soap
P21S Polishing Soap
I used all the above . . . but it's always the final stage of my cleaning.
This is how I (used to) clean exhaust tips on my car (can't be bothered these days)
#1 First step, I used some of my older Microfiber towels and wipe off as much of the deposits from the tailpipes.
#2 Next I spray P21S Total Auto Wash outside & inside of the tips
(It's Citrus based cleaner and great at cleaning contaminants from all various parts of the car) If your really stuck, WD-40 will also work . . .
#3 Next I use OOOO Super Fine Steel Wool - cleaning inside & outside using very little pressure.
One of my older cars had powder coated tips, in which case I didn't use the steel wool on the outside, only the P21S TAW
#4 Rinse off & wipe down with Microfiber towel
At this point, the tips should be looking good, this is when I pull out the Polish.
I've used both with good results:
- ZYMOL METALL BRITEWORK POLISH KIT
- Meguiar's chrome polish
Rest In Peace Jaak
Cable Guy
Cable Guy
Canadian Tire sells "The original Never-Dull" magic wadding polish. It's about $10 and cleans all metal surfaces including 911 exhaust pipes as we proved a few weeks ago. A friend that details tried this out on his 04 C4S and it's now in his tool bag. Works on rusty tools as well. It's in a blue can.
