Flashing CEL, misfiring
Old Apr 22, 2011 | 11:04 AM
carguy88's Avatar
carguy88
Default Flashing CEL, misfiring
Got my car back with clutch hydraulic hose/connector issue resolved. Next day, go to start car, and it idles rough, sounds like not all cylinders firing. Check engine light starts flashing. Stopped car, started again, same thing.
I know I need to get the codes read, but don't want to drive car like this, and figure they will show cylinder misfire, still will need to find problem..any ideas before I take some action? I had MAF and AOS replaced 2 years ago, so I would hope neither of those are the issue.
Old Apr 22, 2011 | 11:05 AM
carguy88's Avatar
carguy88
FYI, this is a 2001 Boxster S.
Old Apr 22, 2011 | 11:11 AM
pongobaz's Avatar
pongobaz
Mike,
what's the mileage and when did you last have your plugs and coils replaced? A couple of cracked coils would certainly cause this type of rough idle. I have a code reader and if you want to swing by we can plug it in and see.
Old Apr 22, 2011 | 11:32 AM
Jake Ok's Avatar
Jake Ok
Yes happened to my 02 996...same symptoms except I was on the raod when it happend. Sucked!
Spark plugs and coils.
Old Apr 22, 2011 | 12:00 PM
ScrnPrntr's Avatar
ScrnPrntr
I have to concur.. same thing happened to me last Sept. Coil packs and plugs..
Old Apr 22, 2011 | 12:38 PM
Christien's Avatar
Christien
Don't drive it with the cel flashing. Get it towed, even if only to Canadian tire or something to have the code read.
Old Apr 22, 2011 | 12:48 PM
AM993's Avatar
AM993
+100. Flashing CEL means "turn the engine off immediately".
Old Apr 22, 2011 | 04:35 PM
Turbodan's Avatar
Turbodan
go buy a code reader, I think they are on sale at CT this weekend. sounds like coil pack
Old Apr 22, 2011 | 06:38 PM
JoeFerg's Avatar
JoeFerg
The absolute last place I would take a Porsche is Canadian Tire.
Take it to a proper Porsche shop that has the PIWIS tester.
Old Apr 22, 2011 | 09:55 PM
mjh1's Avatar
mjh1
Code readers on sale at CT for $100.00 50% off this week. less than cost of a flat bed, you might find out its something you can DIY.
Old Apr 25, 2011 | 01:07 AM
carguy88's Avatar
carguy88
Thanks all...won't drive it, will get it towed to mechanic, get him to read codes, check plugs & coils.
Old Apr 25, 2011 | 04:47 PM
carguy88's Avatar
carguy88
Update: spoke to mechanic, he said try it again and see if it runs ok, if so drive to him. I started it, ran fine like usual. Odd. So drove to him, they looked at coils, all good. No codes reported.
So, this may have been a fluke, I did notice the white smoke syndrome when I started it, maybe I just haven't driven it enough, need to go on a good run and burn some deposits off. Is fuel injector cleaner a good idea, and can any be used?
Mechanic also bled my clutch again as it needed that. I hear they can take a few goes to get pressurized properly. I prob will do the clutch later this year.
