US 996 - Wiring DRL to Fog Lights
I am just about to take delivery of my 996 C4S, imported from Phoenix, and know that I need to get my daytime running lights (DRLs) hooked up. My options are:
1. Take it to the dealer and have them do a $600 modification to enable the DRLs;
2. Take it to a local auto electrical shop (Car Guys in Calgary), where the guy says he can hook up the "fogs" (inner teardrop) as DRLs for half of the dealer's charge;
3. The $10 mod, well known to everyone here.
Comments/thoughts?
Comments/thoughts?
I know it's not the same car, or purchase price, but I did the mod myself on my 944S2 and saved big $. If it's just to pass safety and get your car plated in Canada I would just to the least expensive/easiest way and get it plated then do what you want!
Comments/thoughts?[/QUOTE]
Do it yourself, there is a DIY thread on here, this is someting a five year old can do and will leave you scratching your head why someone would pay the $600 at a dealer for the same result.
Comments/thoughts?
Comments/thoughts?
For me - well I want to turn OFF the headlights as my DRL's and use the Audi style LED DRL's that are being shipped to me. I'm going to install and wire in and my intent is to bypass the DRL 'headlights' mode. My fog's will still be fog's if I choose to use them (not that they work that well being so high off the ground). I have to isolate the circuit that turns on the headlight's when the key is turned and direct the 12V to the LED's. I may even tie in the side marker lights and the LED DRL's as turn signals so that they both flash for direction.
I'd do the VW mod to turn on your fogs as DRL's if I were you - but it's more like $30+ bucks up here now for that relay.
