Tire rack source
I'm finishing off my garage extension and want to get a wall mount tire rack like Tire Racks sells:
http://www.tirerack.com/accessories/detail.jsp?ID=164
Does anyone know of a Canadian source for these, or something similar? I like Tire Rack, but I'm getting bugged by UPS charges.
Update on the Canadian Tire tire rack: it doesn't work.
The end frames are supposed to be mounted on wall studs, 48" apart, i.e. three 16" stud widths. The problem is that the cross bars are 50" long.
So this rack would only work on an open wall that has no drywall, where you could nail a two by four doubler or tripler to your existing studs, to mount the end frames. I got the last rack in the store, and noticed that my rack was already a returned item.
Finding this out cost me the better part of a fine afternoon, when I could have been going out for a last drive, before the car goes into winter storage.
The only option would be to screw in a frame on the outside of the drywall that does match up with the studs and then mount the tire rack with lag bolts to this frame. More work and doesn't look as nice but it is a solution to returning it.
This is aluminum and made for trailers, but I think still a decent value for storing 8 or more tires (depending upon size):
![Name: PitPrdTireRack.jpg
Size: 52.0 KB](https://rennlist.com/forums/attachments/rennlist-canada/485345d1288615377-tire-rack-source-pitprdtirerack.jpg)
http://www.pitproducts.com/8sptira.html
Can also be folded up against the wall. For a garage installation, probably wouldn't need the hardware for running the pipe thru the the wheels.
Captain Obvious
Super User
Super User
I made my own using leftover 2X4s. Only took 2 hrs to make and depending on the width of the tires it holds 9-10 tires. If you do this, you can make it as wide as you need to.
You can see sort of see it at the top corner of this pics.
![Name: Platform storage.gif
Size: 28.4 KB](https://rennlist.com/forums/attachments/rennlist-canada/485363d1288619091-tire-rack-source-platform-storage.gif)
http://www.brookstone.com/HEAVY-LIFT...:referralID=NA
There are others on the market; this happened to be the first one in my Google.
I have the CDN Tire rack and have used it in my past 2 houses....it definately mounts at 48" centers. The red vertical end brackets have to be mounted with their mounting plates toward the center of the rack. Also the chrome tubular bars are 2 piece with one half a little longer than the other so you have to be careful when you puy them together to make sure you pair one short with one longer bar for each section. Great rack, and usually on sale at least 2-3 times per year...I think I paid $89 or $99, but it does take up alot of wall space.
I also just recently picked up 3 of the Cdn Tire wall mounts (yet to install) on sale for $77 each (reg $130). I believe Princess Auto, in their last flyer, has them on sale as well (looks very similar to the first photo on this thread). On sale for $66 regular $129
...one half a little longer...force4rmr
Bahama: you'll want to check this out before you start drilling.
Canadian Tire has a 90 day return policy.
