Good Porsche mecanics in Montreal?
WeTune is one of the top Porsche shops in Montreal, they're at
1400 Norman in Lachine ( 514 ) 633-1497 and Andrew really knows all about the older models.
He supports a lot of cars in the Rennsport PCA crowd as well !
Rombotis Tuning is no longer at that location. They have moved their shop to Laval. Good people to deal with. Andrew at WeTune is also highly recommended especially for upgrades and track applications.
There are many variables ... depending if you want to replace the water pump and rollers while you're there or just the timing belt ?
Give Andrew a call at 514-633-1497 , he'll steer you in the right direction , they know 944's at WeTune /AGM
Cheers
Phil
Cheers
Phil
Phil, 100% agreed - this is really a question of "while you're in there". Nothing more frustrating than coming back for a water pump just a little later, esp. when the labour was already 'paid' for. Also depends on the service history of the car and whether the prior work was documented as to elapsed time and mileage.
In any case, please call Andrew for an estimate and advice on the most sensible/cost-effective approach here. You can check out the new website www.agmperformance.com
Cheers
Matt
Cheers
Matt
