Battery Help
I also performed a load test at 1/2 the CCA and the voltage was dropping far too quickly.
So its either an East Penn, AC Delco or Audi battery (half the price of the Porsche battery) this week.
I attached a cigarette lighter plug and wires to a spare battery and plugged it into the lighter outlet.
NOTE: when you disconnect the battery, make sure the positive terminal is then insulated (wrap a rag around it and tape it up), because powering the car up with a spare battery through the lighter outlet now makes your battery terminal "live". If it shorts to ground, you're in for a surprise.
That is fine as long as the battery maintainer puts out pure DC and as long as its current capabilities are greater than any draw due to an interior light, etc.
Many charging devices are called maintainers. They don't all produce DC.
By the way, I installed a new battery today. The last one rolled over and died when I did a load test at 1/2 the CCA.
According to East Penn, they are an "exact fit OE replacement battery" and sure enough, they are, right down to every detail on my last OEM Porsche Moll Kamina battery.
East Penn 648MF
Battery group size: 48 (DIN H6).
Specs: 70 Ah, 700 CCA, 875 CA, 120 minutes RC.
Size: 280 mm long, 175 mm wide, 191 mm high.
More East Penn 648MF battery pics.
The original battery that Porsche supplied when the 993 cars were delivered was a group 91 which has the same dimensions as the group 48, but is shorter at 175 mm high. Electrical specs are down a bit as well.
East Penn 648MF
Captain Obvious
Super User
Super User
I get my batteries at the local wrecking yard. With a group size number and a tape measure in hand, I can have a choice of two skid full of good used batteries. I pick the newest and best brand name I can find and at $25/each, with a 90 warranty, I can even have a few spares sitting at home for testing purposes. I know this is not what the OP was looking for but maybe it'll be a useful information to someone else that reads this tread.
