944 Speed and reference sensors
I may need a set for an 85.5 944, it's cold and i would have to pull them off a car in the west end it's like -15C.
That sounds like fun.
Compatible Parts
The BMW sensor(s) are direct direct replacement(s), the difference is the longer cable, you can just tie the extra cable into a loop with cable ties.
944/968 Bosch # 0 261 210 003 (marked on the sensor removed from a 944)
BMW part # 12 14 1 708 618
The F6010 numbers used on several websites and a local German car shops can be used to find the sensor(s) as well.
An OEM (Bosche) Number for the 944 sensor is F6010-12761
An OEM (Bosche) Number for the BMW sensor is F6010-12760
Here is the BMW Sensor at http://www.autopartsway.ca
http://www.autopartsway.ca/AutoParts...er=F6010-12760
...compared with...
http://www.autopartsway.ca/AutoParts...er=F6010-12761
...compared with...
