996 C4S Emission Test (ON) - PSM ?
Hi -- In Ontario and due for emission test.
Should PSM be turned off during 996 C4S emission test ? Was wondering if there might be any damage if it was left on.
Thanks.
Thanks.
Your awd, so they only do a idle test and rev the engine to a certain rpm test.
Do not allow them to put it on a dyno or your car will require alot of $$ to fix it.
You need a 2 stage idle test. Do not do a drive test. Be sure to drive your car hard to warm it up before the test. A min of 20 min drive should do it and make sure the test center doesn't allow your engine to cool down.
GL
GL
Team Owner
The guys at the test centres I find are pretty good .. with the 2 stage idle it doesn't even check your cats so you should be fine .
If I remember correctly your Hydrocarbons readout should be N/A for the 2 stage idle test, and this is the check of your cats .. so looks like quite a few guys with C4S cars wil get lucky when it comes to bad cats ..
Team Owner
