Whats the best way to prevent tire flat spots while winter storing?
I have always thought that storing in a cool dry location is better for your car due to the simple fact that oxidation occurs at a lower rate when the temperature is cooler. Am I correct here?????
AL
AL
Captain Obvious
I store my car in my garage...I don't overinflate, I never have any flatspots.
Cool storage is better IMO...my brake rotors are usually clean as a whistle in the spring.
Rest In Peace Jaak
Cable Guy
Cable Guy
Inflate the tire to max pressure, buy some of that 2 inch styrofoam insulation from Home Depot, cut out four 2 feet long pieces that have a width that's a few inches wider than each tire. When you drive the car onto the blocks each wheel will sink into and be cradled by the styrofoam. It's cheap, cost effective and works as good as the tire cradles. The excess styrofoam can be used the following year or you can help out a buddy or two.
for oxidation cooler is better..but bad for things like rubber and gaskets etc...If you have cleaned the car of any road debris and salt then there should be no issue with storing in warm temp.
Captain Obvious
