Have you tried this?
Press and hold the recirculation button. Then press the temperature up ("+") button to switch between degrees Celsius & Fahrenheit on the Climate Control Temperature and Instrument Panel Outside Temperature displays.
The imperial to metric display is adjusted with the clock adjustment ****, by pressing & turning to the right and holding for 5 sec. This will change the speedo, trip, and outside temp display. Glenn's info will change the display on the A/C unit. IIRC
