1986 951 FS
Have a 1986 951 for sale in Victoria- She needs paint and a wee bit o' tlc, but should shake out fine- Good winter project or DE- still registered out of the states, so needs to be imported- I can handle same and pass on cost to you-
without importing-6500.00 OBO (last serviced at SCAN Automotice (Vancouver)
Bad-
PO rebuilt car after fire in engine bay- replace w/87 engine and 'S' Turbo- Car has CLEAN title! I put this under 'bad' because this is NOT a numbers matching future car show winner
VIN WP0AA0954GN154370
needs tires, odo broken, figure about 130K ( I have a new (used) odo with 124K on it waiting to be installed)
PO installed aftermarket A/C, SCAN thinks same should be replaced.
Rad leaks.
P/S pump leaking.
Oil Leaks behind timing covers. (PO (Rennlister) rebuilt engine less than 14K ago, so unsure about this, however for the sake of arguement less go w/worst case) figure that it needs a re-seal)
Final drive seal leaking.
Brake fluid needs flush.
Car needs Paint
Good-
replaced KLR/DME (Parts Heaven) new uninstalled GURU chips, as well as old KLR/DME (one is still good, can't remember which).
New plugs, wires , serpentine belt, power steering belt, left control arm rebuilt, H4's and OMP pedals, fuel line, aluminum sunroof hinges, new sunroof gears,fuel pressure damper, oil/filter change (200 miles on same),wind deflector hinges, brakes have 80% Front and Back, good clutch, LSD!, dash cover- Interior is in good condition, dash has usual cracks etc, A pillar gage pod, updated cd player ( rear speakers are D.O.A.) updated white faced gages and dah lights ( gages are not my thing nor is the gage pod)
PO installed M030 susp.
I have tried to give you the solid skinny on this car- much more so than the PO did with me- pure BS on his part, so I dont need that kind of karma in my life if you can dig it...
These pics are as I saw her in Oregon- Im currently in Mexico and the car is in my Brothers driveway in Victoria ( too much chirp chirp about same so in order to keep family happy Im going to see if I can sell her-)
Please feel free to contact me at fhogan65@yahoo.com or leave a message on my cell 778.994.9214
TIA
Frank
