OT: Home Theater Sound
#151
Omar
Many Ians...not a usual occurence. I am located in Toronto...my summer home is on one of the Rideau Lakes between Ottawa and Kingston, approx one hour to Calabogie, two hours to Shannonville and three hours to either Tremblant or Mosport...perfect!
#154
Pocket Sand
connecting an xbox to a reciever is a pain in the ***...stupid cheap microsoft didn't give me an HDMI output on the box and my recieved doesn't output a component signal over the HDMI out to tv.
i LOATH microsoft at the moment.
#155
Pocket Sand
ok...scratch that. everything is setup and video seems to work fine...i can't get audio to work though. Where can i get some speaker cables that have banana clips at the end?
#157
Pocket Sand
yep, banana plugs. i found a guide on how to attach the ends to some bare wire. Going to go grab some bananas from Radio Shack and give'er.
Also, if anyone has an HD-DVD copy of transformers or topgun they don't want, will buy off you
#158
Pocket Sand
wow....every radio shack in the city is out of banana plugs for some reason. no matter though because everything is working
not sure how much power is actually going to my speakers....it says 100watts for front channels, so i gather 50 watts each?
#159
Pocket Sand
futureshop has a huge sale on speakers and stuff until 2morro at noon!
they have the velodyne DSP-5000R subwoofer for 750$ instead of 1050 like usual.
Are velodyne's good subs? this one is kinda big...a 15" with 1000 watts continuous power, but it doesn't play below 20hz like axioms and SVS's do.
Is it a good buy? what am i missing by not having a sub that goes down to like...15 hz?
#160
Below 20 Hz? Hahahaha. They lie. Or it is -9dB down or something. For 20 Hz, you need a room dimension longer than 32 ft, you need large drivers because of the air excitement demand for that large air volume & those large drivers need a gaggle of power.
All for something that is probably not on the discs in the 1st place since the engineer's system didn't go that low either & if it was, you couldn't hear it anyway since the human ear can't hear below 20 Hz at birth.
Ian
Ian
#161
Pocket Sand
picked up the subwoofer today. Toronto to muskoka and back in 5 hrs. Tuning the sub is complicated as hell. Right now i have it set to bypass the on-sub crossover and am just using the reciever's settings to control everything. 704's are running full and reciever is set to dual sub as i find this makes the bass a bit less directional.
I have no idea what "LFE for LFP" in the menu does, so i just left it at the default 80hz THX setting.
#162
Omar, you need a new couch. That one looks like it came from the set of Golden Girls. In fact, I think my nan used to have the same one in her sunroom.
#163
Omar, the speakers look great! Tv fits perfect!
LFP=Linear Field Proximity, ensures a seamless transition between the middle and high frequencies.
LFE=Low Frequency Effects
