Tie Rod End Puller?
You should use the puller if you wish to be kind to both your original tie rod ends and your steering knuckes (ie. spindle/upright). You can remove the tie rod ends without press tool, but it's somewhat of a brutal procedure depending on the tools used.
If you take it to a reputable shop, they'll have a proper set of tools to do the job quickly, without damage to your old/new parts. They will also be able to set your toe correctly before you drive around and scrub up your front tires. A backyard job may require the used of improvised tools, and you might end up with some damaged/marred bits. Then you'll still need an alignment/toe adjustment.
Good luck with the swap!
- Dave.
- Dave.
"Yes" and "No"
I have replaced the tierods and NO you don't need a tie rod puller. Loosen the tie rod nut but don't remove. Pull down on the tie rod and give the steering knuckle a firm rap with a hammer. This should loosen the tappered shaft of the tierod end. Remove nut and allow to to hang....unscrew the tierod and repeat for other side.
Brad
Brad
Thanks for the replies, guys. I finally did some searching & it seems like a doable job. Wayne's 101 covers it too. I am ordering parts to be delivered in Denver while I'm there for business to save shipping & the usual border $s.
Maybe I can finally centre my steering wheel.
Ian
Ian
Hey Ian,
I didn't need a tool to remove my tie-rods, but I did need a SST (funky socket) to remove the ball joints.
I'll drop by and show you what I mean if you want.
Rod
Rod
Thanks Rod. I might take you up on that once I get the parts - and some time to do it. I'm traveling heavily the next 3 weeks . . .
Ian
Ian
