Wanted: 996 5 or 7mm Wheel Spacer
It still will be cheaper if you get them from the States...the dealers there sell them individually, no bolts.... I was hoping to get them locally.
If you need 5mm spacers and you don't want the bolts, ask your dealer for the 993 5mm spacers (same thing). Part number is 993.343.042.00 ans they are sold in single quantities with no bolts.
Super Duper Moderator
Originally Posted by 996
I think you can get them at tirerack by pair.
Marc
No, they are both non-hub-centric. The reason is that with 5mm thickness, you can still use the factory hub that will stick out enough to be effective. I believe that the factory hub is at least 12 mm thick and that offers enough. The difference in part numbers is simply due to packaging. The 993 spacers were available as seperate pieces while the 996/986 spacers were packaged with longer bolts.
