testing 924s parts
Old Jun 5, 2024 | 02:27 PM
hpaulb's Avatar
hpaulb
Default testing 924s parts
Rebuilt the engine years ago. Anyone out there that wants to help me test some stuff. Car stopped running 7 years ago and have done almost everything. Trying to test speed sensors now. Measure ok with ohm meter but not with a scope. No speedo flicker? Also can't test coil. Maybe the ECM so i got another from a Porsche parts yard but the same.
Old Jun 5, 2024 | 03:15 PM
uniquenamehere's Avatar
uniquenamehere
Where are you located? I know it says Ontario in your profile... but Ontario is quite large.
Old Jun 5, 2024 | 08:00 PM
Adamant1971's Avatar
Adamant1971
Have you confirmed if your issue is spark or fuel? If fuel and not running for that long the K-jet will need servicing. If no spark go through the electrics, check power at the coil etc. no spedo flicker usually points to a failed CPS.
