Enclosed trailer recommendation?
Im looking for an enclosed trailer for a Turbo S, to haul it down into the USA for the winter months.
Does anyone have any recommendation to a good make and model. I will be pulling with a newer 1 ton Duramax.
OR if anyone has something for sale, Id be open to hearing about that as well.
Cheers
Cheers
Look at ATC. Bluewater is a dealer near London.
solid trailers.
also look at Aerovault. Seem well made and if you only need space for a car and few bits, then all you need. Spoke to daughter and founder at Rennsport, good people that care.
i own neither yet but have researched.
solid trailers.
Miska Trailers in Waterdown area makes their own and I believe they have car haulers.
I will look into these thanks guys.
BTW, I am in AB
BTW, I am in AB
Are there any large trailer dealers in alberta then? Rhyming off a bunch in ontario is useless for you.
I'd look for a 8.5'w x 24'L tandem axle enclosed car hauler. Should be setup with a proper ramp door and tie downs.
anything else is cosmetic add-ons up to you if you want.
Definitely go for a 24ft if the budget allows it , i have a 20ft for my SP2 car and with all the stuff i carry it's barely large enough.
You never have too much room in a trailer ...
Cheers
Phil
Cheers
Phil
Angryinch (01-17-2024)
Thanks guys, I will look into the ATC and a 24ft
I wanted something low enough and with a side door. My folks have a hauler for their classic cars, but the 911 doesn't work well with it.
Now that you mention low enough. Check out Futura, saw them at Rennsport too. Interesting products. I think if enclosed I would still lean ATC for size and options for track and transport. Low ramp options are available with Race Ramps.
https://www.futuratrailers.com/
$8000 more for nice interior with some shelves... Or $8000 less for plain wood interior... hmmm...
So I went and looked at these two ATC Rom300 trailers, they are nice, but wow are they expensive for a little aluminum can that they are. These both had hail damage, one is 31 the other 38k....
Think I am going to look around more. I don't necessarily need aluminum. The price is pretty steep I feel for what they are.... Without hail damage they want 55k! Crazy.
If anyone has a nice used unit for sale, please DM me.
Cheers
Cheers
Be patient and find a good used trailer … it’s not like they wear out extensively considered the low mileage they accumulate
over the years , i paid 11K for my 2011 ProLine 7or 8 years ago and it came with full cabinets, a work bench, a screen door , full size side door and a tilted rear
end which makes loading a low car easier.
It has optional smaller doors for a generator and already had a full set of E-track and tow hooks installed.
The only problem is there are more good trailers for sale in the US, no sure how the import details would be ?
Cheers
Phil
Cheers
Phil
Ya, ill look online some more. I need something for the end of March. Ill check rental prices, although I hate renting stuff. We plan to trailer down into the USA next winter so a rental might not be ideal for that.
Used even if you have to drive to the US to pickup.
I imported a used Airstream trailer last summer from the US, easy process. Went and picked up myself. Way more inventory and better value in the US, even factoring exchange rate.
