987 Cayman Part out- brakes, cage, aero, Aim Solo and more.
Hi,
Have the following parts of my 987 Cayman S. Description below, some will fit other models.
More picture can be sent on request.
1) GT4 styled wing made of complete carbon fiber, it is very light. Includes adjustable uprights, and all mounting hardware for attachment (does require drilling on deck lid). Will fit 987/981 and possibly others. $900
2) Heigo, will fit both 987.1 or 987.2 Cayman made in Germany. The cage is in excellent condition, this cage is very easy to install with no carpet cutting, or drilling required. It sits on top of the reinforced chassis designed for the boxster pop up roll bar, and screws onto the seatbelt bolt and strut tower. All mounting hardware included, eyebolts attached and ready for your harness attachment. $1500
3) AIM Solo2 DL forsale, it has the CANBUS cable for capturing all the car's data. Perfectly working, you can pair it up with a smarty cam and easily produce overlayed video for data analysis. I also have a Ram mount and suction cup mount in addition to the roll bar mount. ($90 value)
asking $675
4) Joe Toth composite aero kit
Front splitter - pitted and scratched - common with track use - can be repainted to make it look new again. New $400USD, asking $200CDN
Side Skirts - will fit 987 Boxster or cayman - good condition. New $549USD - Asking $500
Rear Diffuser - for 987 cayman - middle 2 fins have scrapes, it was repaired before with epoxy putty not noticable when installed unless you are under the car. New $600USD. Asking $300CDN
Dive planes will fit 987 boxster or cayman - $ 180USD - Asking $100
If you buy the whole package $1000.
5) Giro Disc 2 piece rotors front and rear Front part number A1-031 Will fit Porsche 986, 987, 996, 997.1 fronts MSRP $1600 +tax- asking $900 per pair
Rear Part number A2-031 Will fit Porsche 986, 987 Rears MSRP $1600 +tax - asking $900 per pair
all parts off the car and located in Toronto, ON.
GT4 carbon fibre wing Heigo Rollbar will fit 987.1 or 987.2 cayman AIM solo2 DL Front splitter and canards Side skirt Rear diffuser Front and rear giro disc
