Xenon Headlight
Hi,
I have a 2008 Cayenne S.
The R Xenon headlight doesn't give that bright white xenon light anymore. Instead the headlight only gives a yellow-orange light. I assume the HID ballast headlight control unit module could fail.
I am at the same time looking looking to replace the complete headlight with an used one because automatic height adjustment is also not working properly.
Anybody who can help finding me a complete headlight and the HID ballast control module would be greatly appreciated. I am located in Toronto, Ontario.
Thanks,
Thanks,
Xenon bulbs should be replaced periodically, they loose brightness over time.
Quick search on Kijiji yields this result:
https://www.kijiji.ca/v-auto-body-pa...010/1555427397
Hope this helps!
Hope this helps!
