QuickJack question
Hey all,
I am considering getting a QuickJack from Pelican Parts in order to work on my vehicles. I have a BGTS 4.0 and a Mazda CX-5 (as the family vehicle). My question to all you knowledgeable people is: Can I get the 7000 lb jack and use it for both vehicles?
Thanks!
Thanks!
whats the weight capacity of the quickjack? I think you should be fine.... I use a maxjax rated at 6000lbs, and it lifts my wife's q7 tdi (5500lbs) with no issues... and I've only got 1 15amp 110v circuit for the entire garage at the moment.
I was looking at the 6000 and 7000 lb ones. It's good to know it'll lift a Q7
I just checked and it shows $1599 CAD for the unit you are looking for.
https://www.costco.ca/quickjack-7000...100757488.html
I believe they are actually a couple hundred cheaper in store as well if you have a truck and don't mind the pain in the butt that is costco shopping haha.. I remember seeing them on clearance a couple years ago for about 1k and in still kicking myself for not buying one as I have a 4 post but this would work well for engine out service on the 911 (engine won't clear my 4 post lift..
Hey all,
Thanks!
Thanks!
I rolled the dice anyway, and did OK. The boxes on the ramps themselves were all torn up, but the box with the pump, hoses and fittings was still intact. Best 1K I ever spent, and it paid for itself within a year. My next addition will be for the SUV extension post which will let me get the car higher if needed, albeit with an extra step in the middle with jackstands, as of course there isnt enough clearance under the car to start with them installed.
Hey all,
Thanks!
Thanks!
The price seems to have gone up as it was $1499 when I got mine and they do go on sale from time to time.
https://www.canadiantire.ca/en/pdp/q...7199p.html#plp
I got mine 2 years ago and have used it many many times.
I have seen the 7000 that Costco sells and I can honestly say its huge and heavy.
The rails are 75 pounds each (vs 100 pounds on the 7000) making it a little more difficult to pickup and put in place.
If you have a large SUV or Pickup then it might be your best bet.
But for regular sized cars and SUV's the 5000 is more than enough.
Here's a video of my car going up:
