993 odometer repair
Old 11-18-2021 | 05:08 PM
Adamant1971's Avatar
Adamant1971
Originally Posted by Turbodan
problem is you should use a special tool to open the speedo otherwise you damage the casing.
I have done several from 928's and have never had an issue separating the halves. I wonder if they are different.
But I do need to get mine fixed as well, I broke the shaft and currently have a section of a bic pen ink tube with the needle mounted to it. It works but I would like to have it repaired properly.
Old 11-19-2021 | 03:04 PM
911 Rod's Avatar
911 Rod
Can you diy calibrate it?
Old 08-01-2022 | 05:16 PM
Luca Essig's Avatar
Luca Essig
Have you got this repaired already?
Old 08-02-2022 | 03:28 PM
911 Rod's Avatar
911 Rod
I sent it to North Hollywood Speedometer.
Service was quick and they did a good job replacing the gear and adding a new trip ****. They did calibrate it, but it's still off a little.
Quick Reply: 993 odometer repair
