Oil Change, A bit over
Team Owner
a few degrees like a sloped garage floor will make zip difference and wasn't intended to. I think Porsche would have a bubble level on the car sill if it was that important. just don't be parked on an obvious hill and it will be fine.
I mistakenly knowing went over up to 0.2L on last change. Easy quick fix with one dropping of the oil canister. More careful next time with priciest measurements...
buying the 911 and driving it has been a ton of fun. Maintenance is also starting to be fun and challenging... lol
wrong. with modern cars it makes a difference
Wow guys. This isn't rocket science.
You think .2 liters or a slight incline will make that much of a difference how do you ever get your tire air pressure perfect.
Team Owner
Team Owner
wrong .. no it doesn't .. what ever happened to common sense..
guess you travel with 5 ft level somehow jammed in your car .. people get so hung up on all the wrong things... like most things don't be stupid and it will be fine..
I measure the volume of oil that comes out by putting the used oil back into empty 4L jugs. Then I just add back what came out. It adds a few minutes to the change and increases the chance of making a mess, but the peace of mind is worth it IMO.
if I am on a slight incline in my garage it will show +/- 1 bar depending on if I back in or not
That's normal. Most car will roll out of the garage into the street without putting the parking brake on, my garage is the same. It is designed this way so water don't accumulate inside.
Captain Obvious
Super User
Super User
This. Mine is sloped enough for water but the cars won't move on their own.
It doesn't matter what it adds up to it's still a ratio of slope over distance. Just because your car is 14ft long the slope didn't get ant steeper!
