Garage heating
Old 06-05-2019 | 09:23 PM
docdrs's Avatar
docdrs
I’m in the process of this as well on a new build. I have an upper floor so I may get a used high efficiency one from my gas guy or buy a new unit. it’s just a matter of being patient. I have a mezzanine to set it in and will put a simple plenum with a diverter to allow lower garage or upper mezzanine heat. Venting is simple pipe for a high efficiency, Gas line isn’t that expensive.
Old 06-10-2019 | 07:50 PM
BIG smoke's Avatar
BIG smoke
Heating? It is all about the insulation.
If properly built, you could heat it very efficiently.
Insulated garage doors. I have never seen a double pane thermal window in a garage door.
Check out this product. https://www.tstud.com/ very cool. But I don't think it is in Canada yet.
I like the heated floor idea. Good lighting, man cave/work area.
This will add value to you property.
While you want it warm, you don't want it warm enough for the wife and kids....
Old 06-10-2019 | 11:24 PM
Porsches's Avatar
Porsches
Insulated quality garage doors. Double pane windows in all windows meaning even garage door windows too (if you add windows). Make sure you confirm the R rating on the doors. Also you need excellent seals on the garage doors where it meets the wall. Spray foam the headers and double bat fiberglass or roxal insulation. And definitely infloor heating with a boiler. Obviously you need the right footings and insulate the walls below grade too. We had walls going to footings that was ten feet below in order to reach bedrock. I researched every possible combination and came up with a good compromise including lots of windows facing winter sun. My build is here. I also have monitored temperature alarms and wired and unwired cameras,
sirens, lights and more as I leave my boats in here. Itemtopia.com. http://bit.ly/2j3BqP4
Old 06-11-2019 | 11:54 PM
docdrs's Avatar
docdrs
There are garage doors with thermopane windows. I had My existing garage R 20 walls and R 40 ceiling insulated and it rarely gets below 8 C in the winter time, Definitely insulate the walls and ceilings first , then good doors. My new house Will be insulated as well, no windows in any doors , just thermopane in the garage for outdoor light.
Old 06-12-2019 | 11:42 AM
911 Rod's Avatar
911 Rod
Originally Posted by Porsches
This sets the bar very high.
Outstanding.
Old 06-12-2019 | 12:12 PM
bcrdukes's Avatar
bcrdukes
Good lord, that's better than everyones house that I know lol
Old 06-12-2019 | 01:53 PM
Porsches's Avatar
Porsches
Outstanding. http://bit.ly/2j3BqP4
Thank you. I appreciate that very much. My goal was something that looked "Canadian" (whatever that means) - but not old or modern. My entire family was involved but I did the 'bigger is better' idea. My son did the design in sketchup after I used my iPad for the overall idea, and I then had the engineering diagrams made. I spent months testing materials and playing with colour choices of stones, siding on windows before settling on this. I planned the landscaping myself and was happy how it all turned out.
Old 06-12-2019 | 04:20 PM
bcrdukes's Avatar
bcrdukes
BBQ @ Porsches' house/cabin/cottage/mansion
Old 06-12-2019 | 04:37 PM
Porsches's Avatar
Porsches
Wink
Bring your 4WD vehicle please as it's down a very long and very bumpy gravel road. But I do have a 200ft dock for your helicopter
Old 06-23-2019 | 12:21 PM
beers4all's Avatar
beers4all
Default Radiant
I did in-floor with a on-demand boiler - no regrets ....
docdrs (06-24-2019)
Old 06-24-2019 | 02:35 AM
peritus's Avatar
peritus
Matt, I have the Reznor. Great little unit.
Old 06-25-2019 | 12:38 PM
Johnny DB's Avatar
Johnny DB
That's your garage!!! wow
Old 06-26-2019 | 10:32 AM
beers4all's Avatar
beers4all
Yes - the cottage garage.
Old 06-26-2019 | 10:33 AM
beers4all's Avatar
beers4all
Old 06-26-2019 | 12:28 PM
Porsches's Avatar
Porsches
I have a similar setup with two zones as well. What is the green thing for in the corner?
Quick Reply: Garage heating
