2000 996 - Engine rebuild(new engine block probably needed)
Old 03-02-2018, 10:28 PM
Netrunnerz
Netrunnerz's Avatar
Default 2000 996 - Engine rebuild(new engine block probably needed)
Does anyone have any experience with having an engine rebuilt with a new block. My engine cracked while at the track last fall and is most likely in need of a new block. Mark Motors Porsche of Ottawa provided an estimate (without looking at it), and it looks like it will cost around $18K for parts & labour... This assumes I need a new engine short block and that my core in not reusable. It also comes with a 2 year parts & labour warranty. Does anyone recommend Mark Motors or any other shops around Ottawa or nearby(Montreal, Toronto) for this type of work?
Thanks.
Old 03-02-2018, 11:11 PM
lowbee
lowbee's Avatar
No info re Mark motor but $18k for a rebuild with 2 years warranty sounds like an excellent deal
Old 03-03-2018, 12:41 AM
Gregster
Gregster's Avatar
Not much around here for complete rebuilding options all the best places are in Florida or Georgia .. Contact Whaletale in Waterloo for used or rebuilding options if you want to deal in Canada or Andre Gaudet Autosport but he deals in older stuff.. 18K without looking at it seems risky.. it could add up to more which already at 18K is getting close to beyond economical repair on a 2000 996 as the value of the car complete is about 20-25k
If you look around you can find a used 3.4L for 7500-10k CDN
Old 03-03-2018, 07:54 AM
JTT
JTT's Avatar
Check with Alpine Autowerks in Calgary too, if you want a second opinion. Marc was very helpful in a recent phone call I had with them and they have lots of experience with rebuilding these engine.
Old 03-03-2018, 10:39 AM
JimV8
JimV8's Avatar
You might want to check with Mark Henry, his shop is near Mosport. I discovered his work when I was checking out a 914 that needed an awesome engine. He also does watercooleds.
​​​​​​​https://rennlist.com/forums/rennlist...gine-****.html
Old 03-03-2018, 11:05 AM
Zookie
Zookie's Avatar
Mark is building my LN 4.0L for me, so he is a great option!!! Amazing Guy
But Porsche now offers the Short Block for $8k plus
it’s the block with pistons and cylinders.
No heads, basically using all the old bits from the old engine, all new gaskets bolt it all up and hit the streets
Plus is $4k Core which is Refunded when you give your ShortBlock back as long as its Intact
Goodluck
Old 03-03-2018, 03:59 PM
halo777
halo777's Avatar
Goodluck
Really? That seems like a great price. How about for the 997?
If you dont mind, can you PM me the ballpark $$$ that you are paying for your 4.0L build with Mark? Thanks!
Old 03-04-2018, 02:02 AM
Torontoworker
Torontoworker's Avatar
Goodluck
Didn't you get a rebuild in Michigan about two or so years back for cly wall scrubbing?? Did that go wrong?
Old 03-04-2018, 09:45 AM
Netrunnerz
Netrunnerz's Avatar
Goodluck
Yes, Porsche is offering the Short Block for $8394 and the core charge is $3334. However, the core charge might not be refundable since the block might not be reusable. If I buy before Friday, I can get the short block for $6700. Since the engine has not yet been taken apart yet, who knows what else needs to be replaced.
Didn't I read in these forums that you bought an engine from MB Motorsports a few years ago for your 996 for $10K U.S.? Is this the engine you are upgrading?
Old 03-05-2018, 05:10 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
What part of the block cracked? Maybe it's fixable.
Old 03-05-2018, 06:01 PM
JTT
JTT's Avatar
This must be USD?
Old 03-05-2018, 09:53 PM
Netrunnerz
Netrunnerz's Avatar
Top of the block has a hole where the coolant is leaking from, an the cover is cracked...
Old 03-05-2018, 09:55 PM
Netrunnerz
Netrunnerz's Avatar
Originally Posted by JTT
This must be USD?
This is in CDN... 20% discount on classic Porsche parts which was ending on Feb 28th.
Old 03-05-2018, 11:16 PM
theiceman
Team Owner
theiceman's Avatar
Received 1,024 Likes on 728 Posts
Isn't the 996 case half's that envelope a crank box ? Can you not just get a case half that you need ?
Old 03-06-2018, 10:29 PM
GTA_G20
GTA_G20's Avatar
I'd jump on that OEM short block and go from there
Quick Reply: 2000 996 - Engine rebuild(new engine block probably needed)
