AIM Solo - Nurburgring BTG question
Has anyone used their Solo for Nurburgring BTG? I've seen in-car of people using them.
When I look at the GPS manager there is a BTG entry that's point to point like you'd expect but the finish position looks to be all wrong? Anyone experience something similar to this?
Meaning I can't use the solo or the coordinates for BTG dont' work. I think if i could find the GPS coordinates I can move the start / finish markers in GPS manager and make it work
Meaning on a public day point to point at BTG wouldn't work for the starting point being BTG. You can manually set start @ entrance on straight and finish at BTG. Maybe your solo will automatically pull up options like it does in the states at multi-config tracks?
You can get very close. Google NOS and enlarge as much as possible. Use your mouse pointer and right click and select "What's here?" You should get a name as well as coordinates.
Rennlist Hoonigan
which cost no drachmas
Also remember that if it's on and your moving, it will record. Even if you don't get a lap time, you can still access the data after. This is the way to do it after https://www.youtube.com/watch?v=2IFj...ature=youtu.be
