Aim SOLO and AMB Transponder Variance
I always thought AIM solos were supposed to be pretty accurate. This weekend I ran NASA TT. My AIM solo recorded a 1:53.7 and the AMB transponder used for the event recorded a 1:54.7, a full second off.
Curious what everyone's experiences are when comparing an AIM with a transponder. Is a one second gap expected?
Rennlist Hoonigan
which cost no drachmas
A second off is much farther than I normally see (I can't remember a good lap being that far off). Where the other laps in the session correct? How many satellites did you have?
It seemed to be within a tenth most of the day from what I recall. Any way to check how many satellites were engaged by looking at the data file?
Also separate topic but I'm new to analyzing data off my SOLO, what measures are good to look at and what's the easiest way to get usable information from the data? I.E. I'm braking too soon or not applying the throttle early enough out of the corner etc?
Make sure you have the latest Start/Finish definition for the AIM system.
Basic Site Sponsor
Basic Site Sponsor
Received 2,908 Likes
Basic Site Sponsor
Basic Site Sponsor
While all new Solo/Solo DL's come with all tracks and the most current database loaded, some older/pre owned have had their databases added to/taken from or are old.
There is an "update track database" feature in GPS Manager to help you through that.
Firmware is just the instructions to the unit for its operation, no database or config changes (supposedly, but check your MXL2/MXG/MXS after every firmware update, ask me how I know!?!?!).
Rennlist Hoonigan
Check out the attached photo on how to check how many satellites you had. If it was good, then try a GPS lap insert to see if it corrects the lap time to match the transponder. If that works, then you have the wrong (well, different) coordinates than for the timing loop.This video has how to fix some GPS problems and how to use GPS lap insert. https://youtu.be/NY9f6wbop0Y
Rennlist Hoonigan
Try the GPS lap insert and see if that changes the times at all.
If you want, I'm happy to look at the file and do it. I would just need a time sheet to see if they change to what the timing loop had. My email is matt@trailbrake.net
I will gladly exchange data files with you. Denis dot clavette at Comcast dot net. I have full can data on an E46M3.
That is a good satellite count.
I was at TWS this weekend and all times were within hundredths between AIM and transponder. I figure difference is start/finish coordinates in the aim.
How do you set your start/finish coordinates for your aim at TWS, was it manual or do I have an older track map loaded? Mine is a regular Solo, non DL. I'll email you my file also.
Hi Denis, I saw you this weekend but didn't get to meet you. I'm friends with ken o and it looks like you guys had a good battle, congrats on the win in TT3.
Thanks, I'll dig them up. Bummer you have to go in and set all the coordinates manually to get lap times that match transponders.
