A training plan?
#31
On your original idea of a training plan, a subtle change in nomenclature might spur additional ideas.
Instead of a sports approach you might try business - define key metrics such as time reduction for sectors and overall. Define secondary and softer targets and give them all a numerical score. Now give every metric a weight and you can look at the numbers to see what to direct your attention towards next and when to move on.
It it would be pretty subjective and take some work to put together, but it does meet the request for an analytically driven way to direct and therefore structure your learning and progress.
#32
Anyway, I'm not disagreeing and it was just an aside to my main point, which was that slicks are not necessary for most of the learning.
#34
It may be easier in some ways (limits are lower, less Gs, less abrupt loss of traction) but harder in others (more throttle management, more partial throttle areas, need to brake for corners where lift is enough on more capable tires etc.)
Nothing you mention as being harder requires more skill. Higher limits, more Gs, more abrupt loss of traction require more skill. It is important to not confuse the the two.
#35
Originally Posted by MaxLTV
If a coach ever tells me that slicks are the most important thing I need to progress further, I'll be very happy because it means I mastered almost everything there is to driving .
As for the Gt3, my point was that it is an easy car to drive fast. It sounds like you are very good at driving it fast and just want to get better, which is awesome. But you didn't shell out the big bucks because it's a 3200lbs car with 475hp. Go back and read your brochure about all of the technology it has to make it go around a track faster. It's an amazing machine. But all of that technology is working harder so that you don't have to. The transmission, the suspension, hell even the differential is constantly making adjustments to your inputs and the conditions. For me, the less the car does, the more connected I feel to the track and to the experience. YMMV
#36
#37
