Rule of thumb for weight savings
If you come up with one, it may break down if you significantly change weight, power to weight, tire compound, prep/equipment level, or aerodynamic setup. You might be able to do a lot of digging and use NASA results or something like that.
A lot of the street car rules of thumb for things like the quarter mile are based on a 3000-4000lb car with a 1:10 power to weight ratio, street tires, stock suspension, no aero, etc.
With some drivers, 180 lbs will make zero difference in their lap times.
There is no rule of thumb. The best you can say is that weight makes a difference. But you can't quantify the difference without considering all the variables. Even if you know all the variables, you still need to test to come up with a number.
I agree that it varies. It is larger on tracks with more than minimal elevation change, and tracks with serious brake zones...
Received 5,407 Likes
Show me one Porsche driver that weighs 150 and I'll show you 20 that weigh +220.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Last year during the Mid-Ohio PCA event at Indy, I was taken out by an experienced CR in a Boxster Spyder, the driver said I cost him 1.5-2.0 seconds per lap. 215...6'3"....4.55.....run stopper.
Last year during the Mid-Ohio PCA event at Indy, I was taken out by an experienced CR in a Boxster Spyder, the driver said I cost him 1.5-2.0 seconds per lap. 215...6'3"....4.55.....run stopper.![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
MAYBE a tenth of a second (driven back to back both at the ragged edge)
It's easy study professional motorsports and the BOP. Its common to see 50kg added and it really doesn't do anything to lap times. HP on the other hand is worth significantly more, (few tenths depending on what it is) and grip is worth seconds
I think that pros are more able to extract 100% from the car regardless of a bit more weight. At the enthusiast level, IMO, the effects of weight in certain situations and on certain tracks will be more pronounced.
Again, purely based on my experience and observations.
Administrator - "Tyson"
This is what happens when you forget about the extra ballast in the passenger seat.
According to PCA and the SP996 rules, 20HP = 180lbs.
It's easy study professional motorsports and the BOP. Its common to see 50kg added and it really doesn't do anything to lap times. HP on the other hand is worth significantly more, (few tenths depending on what it is) and grip is worth seconds![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
a passenger goes in the right seat and typically sits straight up which put its center of gravity 10+ inches above seat
additionally you can corner balance for ballast but few will corner balance for a passenger
