Watkins Glen - New surface and tire wear
Gents, curious to get some feedback from those who have been on the new surface to know what to expect for tire wear when I'm there. My home track is probably the easiest on tires of anyplace I've ever run and I want to insure that if the new surface is a tire shredder that I come prepared.
Thanks,
Andy
Thanks,
Andy
Very very easy on tires
Very easy. Our daytona prototype at the IMSA race there a few weeks ago could have easily double stinted the tires- very little wear
Rennlist Hoonigan
which cost no drachmas
I have found it to be a bit setup dependent. I've seen some badly grained, worn tires come off the new surface from decent setups, but I have also seen tires that look perfect with little wear.
I ran three sets of Pirelli Hoosier slicks at WGI recently over 5 days and they all showed extremely little wear.
Interesting. I've only driven the new pavement for two days in my Formula Mazda running "soft" compound GY 255 slicks. I had significantly accelerated wear compared to the older surface in comparable conditions at all four corners.
WRONGLY ACCUSED!
Received 3,287 Likes
In truth I felt like there was slightly less wear on the tires. Maybe since the track is now consistently one surface you don't have tires jumping from concrete to pavement and back and that contributes to it.
I also got a bunch of chirping in my tires under heavy braking, especially at turn 1.
Fairly significant graining. Shouldering on the inside of the driver side front and rear which is typical on a FM (runs + camber in rear). There was a toe problem in the rear which did alleviate things a bit but overall the tires were shredded at an accelerated rate. I would say that the wear pattern is what is normal for my car but it just happened very quickly. For me a 'medium' compound for WGI would be better now but unfortunately GY stopped making it.
Another difference was that I finally got my front wing in shape and was able to actually run some downforce with it. We backed some of the wing out and that improved the wear on the 2nd set of tires.
I'll be back there in September and everything will probably be different!
Basic Site Sponsor
Basic Site Sponsor
Received 2,837 Likes
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
