Pic is worth????
Pic is worth????
10,000 words? Escape door on my new Quest/ATC/Becker trailer, with a removable fender liner...this trailer is so well made, clearly by hand and made to order too. They don't store these on a lot.
Re. the Escape Door, why I could bulk up to 300 Lbs and still get out of the car..check out the cute little step between the manly aluminum 16" wheels (235/80/16), whose axels happen to be spread about 12" further apart than a standard trailer. Big tow over the weekend...I'll report back.
That access is better than my Sooner* open trailer.
-Mike
*Don't know what a Sooner open AL trailer looks like? Do you know what a Featherlight open AL trailer looks like? If so, it looks *a lot* like the Sooner.
-Mike
That's very clever. I don't think I've ever seen a trailer with a side door like that. Cool.
The fender liner slides out, great fit and it is in and out in a minute.
Follow up....Just back from about a 500 mile round trip tow with the new trailer, Paso Robles to Van Nuys (Lance Aspesi's shop), to Rancho Cucamonga (Next to Fontana, location of AutoClub California Speedway.) and back to Paso Robles.
1. Getting in and out of the car in the while the car is in the trailer, a breeze with the Escape Door,
2. Towing: The rear axels are spaced 12" further apart than the traditional two (2) axel trailer. This leads to added stability of the trailer when towing. My outbound trip was across the Mojave Desert to avoid LA traffic...State Highway 138, mostly a two (2) lane road, with large big rigs coming the opposite way...as they passed, didn't seem to rock the trailer in any noticeable way. I was pleasantly surprised. I don't think I am going to need a weight distribution hitch or an anti-sway device. I did use a tongue weight scale to balance the load.
3. Fit and Finish: Impecable...this trailer reeks of quality,
4. Exterior lighting, all LEDs, intense. Interior lighting, more than adequate,
5. Service from Scott at Becker in Las Vegas...very helpful guy.
6. CAD/CAM drawings of the trailer accompany the official quote.
Dislikes:
None....
Dislikes:
None....
Do you recall how yours was? May be worth considering in the load distribution hitch decision calculus.
-Mike
Martin I have the same trailer and feel the same way about it. I'm now faced with wanting to install things on the walls (strap hanger, utility rack, gas can rack etc.) and am looking for a method to determine where the vertical beams are located so I can screw/bolt into them. Have you given this any thought?
I almost regret having the nice wall coverings, it would be a lot easier to just have everything exposed. But it certainly does look nice.
Jeff
Jeff
Still a relative newbie with a trailer here. I was concerned about getting a good tow vehicle because of trailer sway, long wheel base and all that. I've found when towing my open trailer, the only time I really feel tendency to sway is when I'm being passed by trucks or other large vehicles in the same direction. Opposite direction never seems to bother it.
-Mike
-Mike
The load distribution hitch serves to shift more weight to the rear trailer axel, so I have read. I am certain this sort of hitch is a good idea....however with the spread axel feature on the ATC trailer, the axels are 12" further apart than standard, it may not be needed...at least it didn't feel that way to me.
I tow with an extended cab Tundra 4.7. It has a decent wheelbase for towing...and the load I tow, about 6,100 lbs is under the tow limits. And finally, that Escape Door feature is priceless. It's and $1,800 option, and worth every penny.
Jeff
Jeff
I do agree, the spread axle spacing should help with both static and dynamic tongue weight.
-Mike
I've always thought the load distribution hitches provided sway control as part of the package. eTrailer has a decent info page.
-Mike
-Mike
Thanks to Mike for a great reference piece.
What vehicle will you be towing with?
I was at a recent PCA event and saw a couple of guys towing their ATC 24's with Cayennes with no sway control systems. They said they had no issues towing with that setup but I would imagine the tongue weight would be fairly close to the limit.
So far I'm only partially down the slippery slope wrt trailers.
-Mike
