Time to "Eat Some Crow"...
I had a 20' 2003 Haulmark enclosed. I used it for over 10+ years, and decided to go the open trailer route when a Featherlite open trailer fell into my grasp at a very attractive price. Had that for a short time and then went for a Trailex open..it was 300 Lbs. lighter than the Featherlite (Of course it was, it didn't have a fill deck as the Featherlite does.)
I had fully rationalized that the open was just as good as the enclosed, WRONG. A few of my fellow Rennlisters told me I might be way off base going from enclosed to open...they were correct.
Sold the Trailex and ordered a 2016 Quest Aluminum Trailer:
8.5'W x 20'L x 6.5'H, (2) 3500# Torsion Axle(s).
It took several months to build it and it was well worth the wait. Today, 6/6/16, just picked up a my brand new ATC at the Becker Las Vegas office. It was built to order...I'll have some pics up tomorrow. I also had the opportunity to tow a load with it today...brought a pal's Spec Boxster back home from LA to Paso Robles a 4 hour tow. Towing in fairly stiff winds over the Interstate 5 "Grapevine", the trailer was rock solid. The trailer axels are spread about 12" further apart than a standard trailer. Perhaps I won't need a weight distribution hitch and anti-sway device.
Loading it was a breeze, with the DOOR - ESCAPE - PREMIUM - 88" X 66" - TOP HINGE - FLUSH LOCK - REMOVABLE WHEEL WELL ALUMINUM STEP
ONE PIECE REMOVABLE INTERIOR WHEEL WELL EXTERIOR FENDERETTES INTEGRATED INTO DOOR. This Escape Door is flipped up, the fender liner lifted out, and you can open the car's driver door up wide. If you have a full cage in the car this features makes getting in and out of the car so easy. No need to winch the car in and out of the trailer.
Back in the enclosed fold, and NOT leaving.
I was probably the most vocal. I was on your case about the rationalizing and didn't buy it for a minute. I truly believe you wanted the open trailer setup to work perfectly for you. I just couldn't see how it could.
I am not you. The open trailer might have worked fine for you and I should have been more open to that. I should have been less vocal and I apologize for that. But I am glad to see you back with an enclosed trailer!
Have fun!!
Have fun!!
Once you go enclosed you're done. I see it time and again with my track buddies. And why I stick with open. For me it works and is simple.
Sounds like,a nice setup
I tried the open route, Lord knows I tried, BUT, I simply bring too much "stuff" to the track. I fill three storage boxes, + one set of tires at a minimum + the jack and jack stands.
I went through the three (3) boxes and simply cannot identify what I could leave at home. Here is the good news, when me or my racing buddies, needs race pads, fluids, bleeder bottle, and most of the stuff that one might possibly need, it always seems to be in one of the boxes.
Open works for some, it just doesn't work for me. You guys have been great on this topic. I'll het some pics up today...and focus in on the detail work that goes into these ATC trailers.
1. Privacy when towing or parked away from home,
2. Weather protection, one of the first times I took my first open trailers to the track, it rained. Of course I found myself hanging out in my friends enclosed trailer.
3. Protection for the car from road debris,
4. Less time to get prepped for a track day. It's a matter of hooking up the trailer, reviewing my check list (3 pages long), down the driveway and gone.
But as with most things, there is something for everybody, based on their needs and budget. See some of you at the rack.
WRONGLY ACCUSED!
Received 3,242 Likes
In addition to all the obvious advantages I love the home away from home feeling of a nicely appointed trailer. I bought a $50 microwave, cheap stereo, and good generator. Makes it really nice in between runs.
That being said, I miss my open trailer for the short runs to the shop. Also miss the attention ***** factor of everyone seeing my car. I guess I wasn't hugged enough as a child.
The Penguin King
GT3 player par excellence
resistance is futile.
enclosed, after all the and/but/if.... enclosed is it.
