GPS placement suggestions on 944
I am putting in an Aim data system in my 944. I am looking for the best, and easiest, way to locate the GPS transmitter on the roof. I am trying to figure out how to route the cable without drilling holes if possible. All suggestions welcome.
Strap it to the middle of your dash under your windshield somewhere. Works for me and avoids complicated cable routing. Alternatively, put it on your left front fender.
Put it at the center of the back of roof near the hatch. Open the hatch and peel back the rubber seal and slip the wire under it, run it under the seal towards the side of car to keep from bending the wire too acutely. At some point you'll have to cross under the seal so the wire will be on the inside of the car. Then run it up to the AIM unit, hiding it as you wish.
Dash is out of the car, but I wonder if I could attach it to the inside windshield?
I tried routing it through the rear hatch, but the metal connector on the end of the cord doesn't fit between the roof and the hatch frame.
Thanks for those ideas though.
Basic Site Sponsor
Basic Site Sponsor
Received 3,340 Likes
Every manufacturer recommends placing the GPS antenna as high as possible outside with a metal backing (roof, fender, hood, HAS to be magnetic), such that it has at least 180 degrees of horizon available to it.
The amplified antennas (the GPS-05 and 05B) can work satisfactorily inside on the dash or on a high rear deck under glass. The VBOX, EVO4 and MoTeC L series antennas should be outside.
Biggest danger is pinching or cutting wires.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
Rennlist Hoonigan
which cost no drachmas
I also always recommend placing the antenna on the centerline of the car. That way when you overlay data and GPS lines, the reference point will always be the same versus one car has it on the right and one has it on the left. Small detail but helpful.
Looks like you have some good suggestions.
I asked this question in an install thread I started in the Data Acq. forums and likewise got some good suggestions.
I think it is a good idea to ask local folks with the same type of GPS/data system that go to the same tracks that you intend. In my area, I found quite a few, perhaps a preponderance, that have the antenna mounted under the windshield. In some cases, a shop that sells and installs the systems picked the location. All report that it works fine for the more local tracks in most types of sedan cars.
In my case, I nevertheless decided on a roof top install. But I wanted to drill the smallest hole possible. The connector on my older-style GPS antenna is pretty big and would necessitate a ~3/4 inch hole, so I decided to cut it off, feed the wire through my small hole and reterminate. I was able to get connector and pin sets directly from AIM for $11 each. I botched my first try, but the second one was fine. I did not use any type of special crimper.
Basic Site Sponsor
Basic Site Sponsor
The advantage of working with specialists is access to a wider array of experience and hopefully, a shop will buy from dealers that can offer the global level of support. Makes for less hassle, happier customers and better outcomes.
The manufacturers are very clear about best practices, which is why the roof mounting eliminates variables and is best practice.
Rennlist Hoonigan
No slam on shops that sell this stuff, but they are a sample of one. They have habits and methods that have worked for them, and sometimes, when it doesn't work, they don't look beyond what they have always done and blame the equipment.
Center of the roof is best to give the antenna the best view of the sky.
Basic Site Sponsor
Basic Site Sponsor
No. I use the GPS-05 under fiberglass, too.
Rennlist Hoonigan
I have a GPS08 that I'm using this weekend. Its o e of the first in the country. I've of used it o and off the trailer before but it has quicker satellite lock and picks up more satellites. I had 15 while in the garage on the initial startup.
