DE question: car numbers
Old 03-10-2016 | 06:38 PM
FergusH's Avatar
FergusH
Default DE question: car numbers
Hi all,
How do most driving groups handle the scenario where you've got:
1. One car
2. Two drivers
3. Each driver is in a different run group
One number for the car? Or a number for each person, so the car will need two numbers?
Thanks.
Old 03-10-2016 | 07:20 PM
Frank 993 C4S's Avatar
Frank 993 C4S
Originally Posted by FergusH
Hi all, How do most driving groups handle the scenario where you've got: 1. One car 2. Two drivers 3. Each driver is in a different run group One number for the car? Or a number for each person, so the car will need two numbers? Thanks.
One number for the car.
Old 03-10-2016 | 07:21 PM
ExMB's Avatar
ExMB
Personal experience has it as 2 different numbers in the regions I participate with. Best to contact the region putting on the event and ask them.
Old 03-10-2016 | 08:24 PM
JayG's Avatar
JayG
the number identifies the driver not the car
If you are sharing a car, it is not uncommon to add a 1 or 7 in front or after the number
For example
driver 1 is 555
driver 2 could be 1555 or 5551 or 7555 or 5557
Its easy to add a 1 or 7 with tape
Old 03-10-2016 | 08:41 PM
onefastviking's Avatar
onefastviking
Blue painters tape does wonders if needed. adding a 1 before or after a number is real easy. Although more than likely they will just use 1 car number for the two run groups.
Old 03-10-2016 | 08:48 PM
Veloce Raptor's Avatar
Veloce Raptor
Forget numbers. Use scientific symbols. Stand out...
Old 03-10-2016 | 08:58 PM
Frank 993 C4S
So they make you change car numbers between sessions? - that's crazy stressful.
Old 03-10-2016 | 10:26 PM
Matt Lane's Avatar
Matt Lane
Considering our flaggers are typically doing Wonderword and puzzles, I don't think the extra digit is going to make a huge difference.
Old 03-10-2016 | 10:27 PM
Coochas's Avatar
Coochas
It seems odd to me too! As far as I can remember, NCR and NER PCA DE used the same car number when the car was shared. In fact, my wife and I shared the same numbered car but ran in different run groups for years.
When I worked Control with PCA, we had a sheet for EACH run group with the list of cars/drivers. For example, the yellow group might have number 255/Ben Dover and the Black run group would have number 255/Phil McCracken on the rosters.
Old 03-10-2016 | 11:33 PM
facelvega's Avatar
facelvega
Do not let them give you some ridiculous high number. I always insist on 3 and 5. Because I drive flat out.....That's how I drive; flat out......
Old 03-11-2016 | 12:25 AM
onefastviking
I always ask for 11 because I drive more than flat out !
Old 03-11-2016 | 08:17 AM
Veloce Raptor
Which is why I always register either as Craven Moorehead, Peter Gozinya, or Girth Brooks
Old 03-11-2016 | 09:16 AM
LuigiVampa's Avatar
LuigiVampa
WRONGLY ACCUSED!
Wasn't Peter sponsored by Dicken's Cider?
Old 03-11-2016 | 10:08 AM
Veloce Raptor
It was Dick Trickle
Old 03-11-2016 | 10:29 AM
Viperbob1's Avatar
Viperbob1
It was Dick Trickle
They have medication for that now...
Quick Reply: DE question: car numbers
