FS: 2011 6 speed Gtb1 Cayman S
Hi guys,
This car was built end of 2015. Sebring was his 1st time on track.
Had some good results and prove that a 6 speed Cayman can do well versus a pdk car. Dont be afraid to buy a 6 speed car.
Best time at Sebring: 2.17.7 on 5 HC tires and full gas tank.
All parts on the car are brand new, unless noted.
Engine:
Fabspeed race mufflers
Cargraphic race headers
Softronic tune
runs on 94 gas, no race fuel
Setrab big transmission cooler with fan and Weldon pump
OS giken differential
Aasco lightweight flywheel with stock clutch
CSF aluminum sides radiators with 1 fan only and center radiator
Deleted gas evaporator tank
Electric power steering pump with AC delete
Suspension:
JRZ double pro suspension with top plates and quick disconnect (freshly serviced)-used
Porsche Cup lower control arms all around
Tarett solid end bushings
Wevo solid transmission mounts
Wevo semi-solid engine mount
Tarett front and rear swaybars with extended droplinks
Alignment and corner balance
3.9 front camber/3.4 rear camber
3080 lbs with driver and full gas tank and +- 50 lbs ballast inside the car
Body:
997 front end conversion
997 OEM front fenders
997 gt3 style fiberglass front bumper
997 carbon fiber headlight covers
997 gt3 front fender liners
997 fender liners
997 cup front lip
RS style wing in carbon fiber with trunk base with cup sides wings
Cup wing uprights
Lexan in rear trunk
Lexan in side windows
Aerocatch on Hood
1x set of oz wheels with Pirelli tires (8.5’’ and 10’’)- red/black/silver color available
Rennline front and rear tie downs with stress bar in the back
Rear bumper cut with black grill
New wheels bearings on all 4 corners
Rennline front and rear toe hooks
Brakes:
996 gt3 front calipers
AP racing 2 pieces rotors
Stock calipers and brakes in the back
Pagid Black pads all around
997 front knuckles- used
Gt2 brake ducts
Goodridge SS brake lines
Gt3 master cylinder
SRF brake fluid
Calipers studs
Wheels studs
Interior:
Full cage done by Sebastian Rochon (built by Seb),
Omp seat with omp side mounts
Schroth window net
Schroth hans harness
MOMO steering Wheel with quick release
Steering Wheel hook
Cool shirt system with adjustable temperature
Fire supression system
997 gt3 alcantara ****
Porsche short shifter
Rennline Shifter Riser
Rennline track mat
Rennline 4 pedals kit with throttle extension
Odyssey PC925 lightweight battery
Air conditioning and heat system deleted
Electronic:
Radio system with push to talk button
Aim MXL2 color dash with smarty cam Rev 2
Carbon fiber center console and dash panel
Deleted a bunch of wires and nicely installed with proper fuse/relay/box
Kill switch
Car is located in Pompano Beach, available for PPI at a Florida race shop or dealer with a deposit in my hands.
Car could be delivered to next PCA race at Road atlanta for the buyer.
Asking price: 95000$ usd
I can be reach by phone at 1-844-987-PART(7278) or by email at : sales@987part.com
Engine:
Softronic tune
Suspension:
Body:
997 fender liners
997 cup front lip
Cup wing uprights
Lexan in rear trunk
Aerocatch on Hood
Brakes:
Gt2 brake ducts
Gt3 master cylinder
SRF brake fluid
Calipers studs
Wheels studs
Interior:
Schroth window net
Steering Wheel hook
Rennline track mat
Electronic:
Kill switch
WRONGLY ACCUSED!
Received 3,283 Likes
If this is the same car I saw a few weeks ago in Sebring it looks like an awesome build.
