Moton/Motion Control Fill Gauge
Anyone know the best place to buy a High Pressure Schrader gauge/fill hose for nitrogen fill on shock reservoirs?
I think they need to go to 300.
Rennlist Hoonigan
which cost no drachmas
http://www.longacreracing.com/produc...Shock+Inflator
Go with a digital gauge and the shorter the hose the better.
Matt I agree that gauge is more accurate for checking pressures but for filling I use this unit from Longacre: http://www.longacreracing.com/products.aspx?prodid=7270
Once you've filled you can bleed and recheck establishing a baseline then refill to your desired pressure....
I too prefer and use the longer hose version, I've just found it easier to use on some rear canisters when they are tucked away in a mess of rollcage tubes out back.
I've learned approx. how much air I lose in the longer hose section, it's not much, and I always refill accordingly when checked. Typically I'm making a change anyway when doing it and I know where the pressure was based on notes.
I've used both and actually have both although I don't even use the short version anymore, my shorty is a Penske I believe, long version is a Longacre version.
Jellonailer,
If you'd like to try the long version at the track sometime let me know and you can try mine, I can bring up one of my small nitrogen tanks which makes it very easy to add with as well. Which car of yours has the Moton / MCS's ?
I saw the white 964 car at the PCA TWS club race but never could find you. I was up there Sat. and Sun.
See you at the track,
Viking
Jellonailer,
Viking
I have been using this one.. Its for bikes so does not come with a "Motorsports" markup... The head and dial rotate freely, so it can sneak in to cluttered spaced pretty well.
Amazon.com: Topeak Shuttle Air Pressure Gauge Dial with Case: Sports & Outdoors
Certz , 300 psi because I just guessed thats a typical gauge. I don't see many 200 or 250 psig in my business. Yes, I run 175 ish. But I did buy the longacre today!
Onefast - looked for you too that whole weekend. In fact the wife and 2 kids were the grid workers. My 964 has Motion Controls - courtesy Steve Wiener. Darn good set up.
I'm sporting a full beard at moment so I might look a little different too, not sure how long it'll last tho.
Motion Controls are magic, set up properly is the key, 175ish is about right for TWS, I'd go a little less for bumpier tracks like MSRH and Eagles, you'll basically be lessening the effective spring rate a little. I'm sure Steve W. has set you up well. Do you know what spring rate you have currently ?
BTW-any of these gauges recommended will work fine, it's just a little personal preference.
I would recommend using Nitrogen from a bottle for fill up tho. There are always a few people at the track that have Nitrogen bottles and can borrow if you don't want to invest in a bottle. If you let me know when you are going if I'm going also then I can bring my small bottle and regulator, it's easy to use.
Viking
