TPD trailer ordered, what do I need to change?
So my current design is:
8.5x 34' Gooseneck, triple 7k axles, interior height increase to 9 ft, 4 post hydraulic lift to stack cars, 2 16" spare wheels and tires, Stone guard package, d-rings, 60" ramp extension, 6' of wall cabinets; L-shaped front workbench with generator door and sliding rack, 6 drawer toolbox, Superwinch 4000SR and steps up to gooseneck nose; The lighting package with 2 flourescent lights, 2 quartz pan lights, 2 outlets and shore power plug. 50' of e-track location to be finalized, an 8' tire rack across the front of the gooseneck nose.
I think that's it. So what did i forget?
I'm not a fan of the quartz lights they have used in the past. Way too much power and they run really hot. I'd try hard to use as much LED 12V lighting as possible. I do love the 120V fluorescent lights in mine, I think I have 3 in my 28' trailer. More is better. I'd probably ditch them today in favor of LEDs.
I have an outlet near the door and the folding table that supplies power for the laptop, and outlets at the rear inside and rear outside of the trailer. (Don't want to have to open the door if you want power outside.) Also an outlet on the side of the L-workbench to supply power to the coffee and to the chargers for radios, etc. More is better here to.
I have an Onan 4200 generator in mine, the largest that fits the sliding rack easily. It runs the heat/AC and a coffee pot at the same time as the normal lighting power.
If I had it to do over again, I'd ditch the built-in tool box and work bench. I'd get a big 'ol Snap On box and wheel it in and out as necessary. It has enough counter space, and you can customize the counter top material as desired (wood, metal, carpet, rubber, whatever).
What size generator are you planning to use? I'd go bigger than the Honda EU3000is that I've got.
The Warn winch with synthetic rope and wireless remote is the ticket. Montoya (on RL) has one. Ping him for details.
I always use my AC and awning. I wish I'd bought the awning that is all-electric and has no support posts. That's trick. It even stows itself if the wind is too much.
Check out my trailer diary for lots of good info. Feel free to ping me via PM.
I have a 6500 watt generator on mine, runs AC and everything else on the trailer. And if you want to be a good neighbor the trailer next to you. Generators are like cars never enough power. As far as the winch is concerned be sure to get one big enough to drag your car onto the trailer in the event of severe damage, loss of one or more wheels, I went with a 10k winch overkill for most things but.....
How are you mounting your tire rack?
Be sure your wireless remote has enough range to work from where you will be standing (often adjacent to driver's side door in case you need to make mid-course corrections).
Mine is aftermarket (installer forgot I wanted remote) and marginal at that range. In my case it may be a function of where the sensor is mounted).
One item I changed on my trailer was the door extension. I also had the 60-in extension but it made the door so heavy at the end of a long day it would take 2 people to lift it up. I took it off and went with race ramps as my extension instead. Much easier to handle.
I forgot to list 15,000 AC, and vinyl curtain in front of the car so the nose and workbench / seating area can stay cool.
Tire rack will be fixed and mounted on the front wall of the gooseneck. With over 5' of height in the nose, I could put two across the front, but that seems like overkill.
I understand the idea, but is it really worth tearing up a nice trailer to drag a bent car into it this way? I've seen moving dollies or carpet deployed to do this after raising the front of the trailer to reduce the angle difference between the floor and the ramp. Personally, I would try just about anything before making a mess of the trailer like this.
GT3 player par excellence
just ask victor, they have large LED lights for exterior to replace quartz
honda 3000 is not enough to run the AC
The Superwinch 4000SR (synthetic, not cable) is a fine choice. Have had them in both trailers I've owned. Just order the wireless remote in addition to the cable one (backup).
