Sebro Rotors
Old 10-02-2014, 07:25 PM
jscott82
jscott82's Avatar
Default Sebro Rotors
Any experience with Sebro rotors?
Given that there aren't any motorsports options for non-turbo 993's I've always used OE rotors at $170... Now I see Sebro offers replacement rotors (still crossdrilled) for $72...
Any experience with these in a motorsports application around here? 72 bucks just seems too cheap.. but I'm really temped to give them a go.
Old 10-02-2014, 08:25 PM
morsini
morsini's Avatar
Originally Posted by jscott82
Any experience with Sebro rotors? Given that there aren't any motorsports options for non-turbo 993's. I've always used OE rotors at $170... Now I see Sebro offers replacement rotors (still crossdrilled) for $72... Any experience with these in a motorsports application around here? 72 buck just seems too cheap.. but I'm really temped to give them a go.
I think I tried them and they lasted about as long as they cost. That is about a third of the life of an OEM rotor.
Old 10-02-2014, 11:43 PM
jscott82
jscott82's Avatar
Wow... Any faster than OE and they must crack when you take them out of the box...
Thanks for the heads up..
Old 10-03-2014, 08:49 AM
morsini
morsini's Avatar
Wow... Any faster than OE and they must crack when you take them out of the box... Thanks for the heads up..
If you're cracking rotors that fast I'd look into more/better cooling. My rotors last a full season depending on events of course usually 8-10 before they need replacement. OEM are the only ones that last.
Old 10-03-2014, 09:33 AM
Bill Lehman
Bill Lehman's Avatar
I'm running Sebro Slotted on a heavily tracked Cayman S. OEM rotors crack and fail tech, Sebros last much longer.
Old 10-03-2014, 11:58 AM
kisik
kisik's Avatar
I am running my front 330 x 34mm Sebro slotted on my 997.1 C2S. No problem so far. I can see tiny lines on the surface. My drilled ones would have been started to crack. Cooling is a key.
05' 997.1 C2S
Old 10-03-2014, 01:00 PM
jscott82
jscott82's Avatar
I wish there were a slotted option.. But for my car (class rules dictate stock size), all options are drilled.
Short of fans, water, or a EVO bumper (bigger cooling ducts) I've got all of the cooling I can get.
Longevity its not <so> bad, I'm only doing 3 or 4 events a year, and OE last about a year. The problem is my local track (CMP) is hard on brakes.. not to mention the car is 3200lbs.
OE have a very predictable failure mode and cracks develop "slowly" and predictably. My concern (aside from wear) is that they will fail "faster" where I don't have time to inspect before they come apart.
Old 10-03-2014, 03:29 PM
Kein_Ersatz
Kein_Ersatz's Avatar
Will be interested in your results if you give them a try. Subscribed.
OEM and Pagid Bk/Ye seem to get 2 or 3 pads to OEM rotors for full DE duty.
Old 10-03-2014, 11:10 PM
jscott82
jscott82's Avatar
No positive experience with drilled... Anyone????
Old 10-04-2014, 02:24 AM
333pg333
333pg333's Avatar
If you are limited to a certain size why don't you get some custom hats and slotted rotors made up which will be lighter and once you outlay for the hats, the replacement rotors will be cheaper. Try Coleman racing. They'll make anything you want.
Old 10-04-2014, 02:43 AM
Eric_Oz_S2
Eric_Oz_S2's Avatar
I can confirm that the Serbs rotors last about half as long as the porsche rotors. They seem very soft and also reach their crack life about the same time they reach min thickness. Performance wise they are ok.
Old 10-04-2014, 10:55 PM
Viperbob1
Viperbob1's Avatar
We cryo the Sebros to get longer life. Just about doubles it with proper cryo process. Fortunately we do can it in house.
Old 10-04-2014, 11:06 PM
LC MotorSports
Former Vendor
LC MotorSports's Avatar
We have some slotted options for the non-turbo 993. Email me with your details and I will put some pricing together.
Old 10-05-2014, 09:44 AM
Kein_Ersatz
Old 10-05-2014, 01:27 PM
KOAN
KOAN's Avatar
Too bad you can't switch to RS brakes. That made a huge difference with the longevity on my previous track 993.
Quick Reply: Sebro Rotors
