965 Track suspension
RL Technical Advisor
Justin:
Good advice from Glenn,......
It won't be cheap but this works very well:
1) Install a set of Moton Clubsport, 7-way adjustable, remote reservior struts & shocks with a main/tender spring setup.
2) Install ERP front monoballs & camberplates/monoballs
3) Install ERP rear spring plates and monoballs at the trailing arms
4) Install the GT-2 Factory adjustable swaybars
5) Install a strut brace (unless you have a cage)
There are a few more odds & ends, but this stuff works VERY well if its properly configured and installed,....
Hi Steve -
I have a 965 with exactly the set-up you are recommending - am just in the process of installing the Moton Clubsports. The car is striped and has a welded in cage. I'm running Toyo 888 with 305 at the rear and as far as I recall 285s front. Trackdays are mainly northeast - Lime Rock, Glenn NJ. Two questions:
What weight springs do would you recommend given the setup and where can I purchase the GT-2 adjustable sway bars?
Thanks,
Thanks,
I had non adjustable Bilsteins with 700/900 springs, and the various monoball bits as Steve suggests. The trick is getting the shock valving right. I'd consider buying the suspension from Dan Jacobs as he is one of the few that has setup these cars for PCA CR.
However, I would highly recommend against converting a C2T. A Cayman S will be faster and handle better for H class. Plus the C2Ts are getting rare.
Matt, realizing that the OP was 2003, I'm pretty sure the Moton Clubsports back then had simple bump and rebound adjustable with 7 clicks.
Two way adjustments with seven settings.
