Bleeding brake fluid after track event
Track guys:
Is it necessary to bleed/flush the brakes after every track event?
I use ATE Super Gold.
Just tracked Road Atlanta for two days with its heavy braking zone approaching 10A.
Have not-lightened 2011 C2S coupe with Pagid yellows.
Thanks for input and advice.
^ Agreed - I at bleed if not a full flush depending on how the track day went. Definitely take a look around underneath. I got back from the Watkins Glen CR Monday night and found a broken rear drop link today. I was wondering why the car developed such a nasty push late in the enduro...
As long as your fluid is not old and full of mositure, bleeding after every event is probably a waste of time...If you are getting a spongy pedal switch to SRF or Endless racing fluid. Fresh fluid should be fine for awhile...That does not mean that you don't have to inspect the brake components and have a good look around every every event though.
I think it is a good idea and have (almost) always done so.
Also a good time to get the car on jackstands and look around.
It won't do any harm to bleed the brakes after a track day, and taking a good look at the tires wheels, brakes, etc. is also a good idea. I also like to measure the brake pad to be sure I know what is left and see how much I used.
People telling you to change it once a year are nuts. Bleed it after every event. It gives you the opportunity to check the system and all things brake and gives you piece of mind.
Loosing your brakes or having them go soft at the wrong time can be very expensive. This little maintenance job is cheap and requires very little time.
Don't skimp!
Don't skimp!
ZnZBar 986S (04-26-2023)
uninformed gas bag
(contemplating on whether gas bag is one or two words)
Yup. Its not just about the brakes. Or let your shop do it when they inspect before an event. Doesn't cost much and helps create goodwill. You know..... you're just not there for the free look.
JR, the only thing nuts about Tim is the demonic speed he can carry around a track. He's a Nat level SCCA shoe and a great coach, currently working with Nate Stacy on the hunt for a top spot with Pirelli WC.
Although I do bleed after each event, I'll agree that it's probably not absolutely necessary (with the right fluids) - BUT, a through systems check is.
