video cameras
In my opinion, the best solution is a cheap video camera that takes a video input from a lipstick camera. The lipstick camera can be mounted anywhere, will not vibrate like a full-size camera, and you don't have to buy a big, heavy $100 camera mount.
The camcorder itself can go in a padded case in the car. This way, you won't be vibrating an expensive video camera to death.
Go search this thread. There was a nice discussion about this issue about two weeks ago. Dialog about lipstick options and relative costs as well as sites to visit with the different systems.
video
what would the different heights or locations give?
being able to see the gauges would be ok
what about the bumper cams? how is the viewing pleasure when theres nothing in front and down so low?
it'd fit real nice in my grill, now were talking about less than 12" from the ground. how would it look at some good speed, 100 and up? or even slow?
Untier
Since you didn't bother to do a search, I did.
https://rennlist.com/forums/showthre...=video+cameras
Unaffiliated
I've got a Sony TRV520 (digital Hi-8) that I use..it has got a "stable image" feature but I'm not sure what it does..She's a nice unit, not too heavy.. It gets cradled in the IOPort Camera mount which hangs on my Redline rollbar. To expand the camera angle option, I purchased a $160 color vid lipstick cam from supercircuts.com and am experimenting with mounting locations. The first an easiest spot is the passenger mirror, flipped forward. This give a nice view of the fender. Duct tape is suficient as a mount there. I tried the gas cap cover mount, the view down the side of the car is nice but the passenger mirror blocks forward view..yet the driver is visible in the mirror (kindof cool) I've got dreams of filming the suspension, etc.. but mounting the lipstick cam fairly secure can be a challenge. I've run into audio difficulties too, I may need a microphone with more line voltage than the ones I have (RadShack Batt powered mic's) The microphones work great in vidcam mode (thru the lens) but the audio is lost when recording in VCR mode (thru the lipsick cam) I've got close to 2G's in this setup (OK so the rollbar was for another purpose, but you need something to bolt it to) As with most things car related, It isn't cheap to do right
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
A friend at the track showed me a lightweight SD card camcorder (lower power requirement due to no moving parts) that he was using. Pretty inexpensive too. Not sure how long these electronics will last, but so far so good. Pricing was $100 - $175.
Just a couple of things to think about.
Best views are probably top of car, and in the middle behind the seats. 12" off the ground would be neat to see, but difficult to learn anything from.
I have an in-car camera set up that uses a cheap sony camcorder as a "vcr" that's fed by a remote camera that's rigidly mounted on my roll bar. I'm very pleased with the video and audio quality.
I bought my set-up from Bruce at American Raceday. http://www.americanraceday.com (I have no affiliation other than being a satisfied customer).
You can reach him at (951) 536-7497 or bruce at americanraceday dot com. He's local here in SoCal and offers "one-stop shopping" for all of the cables, accessories, etc. that you need + his prices are very reasonable.
Documenter of Ineptitude
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Since I didn't want to tie into my electrical system I went with the Chasecam setup. Powers for 2 hours on 4 AA batteries. I also don't have a nice place to stick a recording device that is vibration free. It handles very unfriendly environments quite well.
I used to use my Sony camcorder but I had to replace it...the only problem was that you cannot find any new camcorders that take an analog input which you need to use the lipstick cameras...so I bought the chase cam setup...expensive but nice.
