Neat AiM RS2 Feature
Rennlist Hoonigan
which cost no drachmas
I haven't seen this documented anywhere, but it's pretty cool. Pull up your GPS map for the track, double right click, and it will add in the track elevation. You can then hold the right button down and rotate the map along with using the GPS map moves on the menu bar.
The first two are Lime Rock. The third is Tremblant. That is a lot of elevation change!
See page 29 of GPS05_101_eng.pdf..
Its documented, but like so much in AIM, not particularly well. The sad part is that some poor programmer busted his nuts programming this feature..
hi matt , ok ,i know this is a really dumb question but i dont have the gps map buttons that you have circled . i do use gps map manager to generate the map . can you tell me what i am doing wrong thanks
Basic Site Sponsor
Basic Site Sponsor
Received 3,216 Likes
After enabling the GPS map (like in Matt's screen grab), highlight the map by clicking on the map and the buttons come up.
This does not work for the standard map under Map Manager. HAS to be a GPS enabled map.
-Peter Krause
www.peterkrause.net
www.gofasternow.com
-Peter Krause
www.peterkrause.net
www.gofasternow.com
