Sparco Ergo seats?
Sparco Ergo seats?
Any shops in the North-east where I could try a Sparco Ergo (removable halo) seat? Seems Stable Energies doesn't carry Sparco seats.
http://www.ogracing.com/sparco-ergo-...ss-racing-seat
Anyone has this seat and willing to PM me their seat size (S, M, L) and their body measurements?
Anyone has this seat fit into a 996 (GT3) or a 997 (GT3)? Any modifications needed or is it a plug 'n play fit?
Anyone has this seat and coming to Limerock soon?
Any downside to having halos in a roll-over with only a half-cage (roll-bar)?
(Currently running with Euro GT3 buckets and considering replacing them with Sparco Ergo.)
HF1:
Unless you are under 5'5" and 120lbs, that rules out the small. At 5'11" 165 lbs, I fit in a medium. I've seen on installed in a 997.2 GT3RS with full interior and and the Porsche club sport cage. The large is definitely for those over 6'2" and 200 lbs.
The seat will bolt in using BK adapters and Sparco sliders. If you have any questions, give us a call at 800.934.9112 or shoot me a PM.
Kind regards,
Kind regards,
That said, the Ergo is both larger and smaller than the popular Sparco Evo. The Ergo has a very straight seat pan and the front of the seat isn't much wider than the back. The EVO spreads out quite a bit. This is important in a street car with an interior because the tranny tunnel comes into play (at least it does on a BMW E36 M3). The bottom line, is the inside seat space is larger on the Ergo than the EVO for a given floor footprint.
I'm 5'7", 250lb. Being short, I'm "blessed" with the torso of a basketball player and my biggest problem was getting shoulder holes high enough. The Ergo M was too small for me because the back was too short. The Ergo L fits me perfectly. For reference, I fit in an Evo US except the shoulder holes are too low. I also fit in a Recaro Pole Position, but the shoulder holes are too low. If you are skinner than me, and the shoulder holes are correct in those two seats, I'm guessing Ergo M. If the shoulder holes are too low, Ergo L and possible cushions if the seat is too wide for you. The Ergo M is quite a bit smaller and easier to fit in the car than the the Ergo L.
I drive my car to the track and the Ergo is more comfortable than the BMW stock seats. Other people who have sat in them comment on how comfortable they are. I have two Ergo L installed. The driver's side is on a slider.
The halos work well. They are smaller than permanent halos and they are easy to attach and remove. I got lazy and left them on and realized they are a hazard. During the day they are fine, as it is easy to look around them, but at night, such as when driving to the track in the morning, being black with a black interior they create a nasty blind spot because you can't see them to know to look around them. After cutting off a few people I've gone back to removing them on the street.
I've only got a roll bar and still have the stock non-removable steering wheel and I can comfortably get in and out of the car.
If you really want plug and play, consider the GT3 seats. There may be other mounting options I don't know about. In the BMW it was far from plug and play but worth it. After making them fit, I fully understand why the GT3 seats command the price that they do.
For the size of the halos, here is Andy Lally schooling me on how fast my car could go at TWS last November:
-Mike
Addict Rennlist
Bill
OG Racing
Your Source For Motorsports Equipment
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Sparco's Largest Distributor for 28 Years
PFC Distributor for 27 Years
Pagid, Alpinestars, MOMO, OMP, Hawk, Bell, Aim, G-Force, HJC,
HANS, Arai, Simpson, Brey Krause, Longacre, CoolShirt!
Supplying Track Junkies for 34 Years.
PCA Club Racing - National Sponsor Since 1998
A Veteran Owned Business
Check out our blog!
OG Racing
WWW.OGRACING.COM
800.934.9112
703.430.3303
info@ogracing.com
Check out our blog!
Assuming I have the correct adapters and sliders (parts numbers?) how complicated is the installation compared to putting the Euro 6GT3 seats in/out (which I can do w/o problem myself)?
Received 1,236 Likes
HF1:
Kind regards,
Kind regards,
I'm 5'8", 145lbs and 29-30" waist, and can't decide if I should order M or S size. I cannot find it to try locally - several shops have my number to call me when they have them, but alas. One has large, but it's obviously too large.
I fit in Sparco Circuit II fine, except holes could be lower and bottom cushion is cutting into the knees just a bit, but the butt area is as narrow as it should be. So Circuit II would work for me and something just a little bit smaller would be even better. A bit bigger would be a workable compromise.
Any thoughts?
Are you being serious about 5'5" and 120lbs being the limit for Sparco Ergo Small?
Any thoughts?
Any thoughts?
My gut feeling is you may fit in a small, although I've never seen one. One thing to keep in mind is if you ever want someone else to drive your car, the small may be too small for them. If, when you sit in the large, the seat depth is a bit too much, and the shoulder holes are 2" high then a medium may work. I can't help you much with seat width. The medium is narrower than the large.
Worst comes to worst, if you buy it from the right place you'll only be out about $100 in shipping if you pick wrong. It's easy enough to try out one of these seats for fit by just putting the unmounted seat on your sofa and giving it a test sit.
I love my Ergo Larges. I've been daily driving the car and other than getting in and out they are much more comfortable than the stockers. The bolt on halos work well and I get compliments from instructors on the setup. The extra wide headrests give protection from the roll bar on the street. I've got the seats, Schroth 6 points, roll bar, front full interior, heat/ac, factory H/K stereo - it's about as good as dual-purpose HPDE car can get.
-Mike
Mike,
where in TX are you? I'm looking at ordering one of these in L and can't find one to sit in. I'm 6'8, 225 (36" waist), so I need something with high harness holes and where the top of the halo isn't down around my cheeks. I've been looking at this and the RaceTech.
Mike,
I don't know if it will help, but I've attached a side by side pic of the Ergo M vs the Ergo L. The L is wider, deeper and the shoulder holes, headrest, and halos are considerably higher. For me, the width and shoulder hole height is perfect, but the halos could be lower as they cover the top 1/2 of my helmet.
BTW, that piece of tape on the the left thigh bolster on the medium was my estimation of the increased width of the large vs the medium based on published specs.
At nearly 7', you will likely need the large and have the thing mounted down on the floor.
-Mike
Addict Rennlist
Here's a link to the seat page showing all the measurement for the 3 sizes of Ergo seats OG Racing
Bill
YesIfit:
If you can hook up with Mike to test fit his seat, also try it with the cushion removed. You are 6'8". Is your height more in your legs, or your torso? If the Ergo Large isn't tall enough for you, two other seats consider are the OMP HTE XL, or the Racetech RT4009WTHR. Info in the links below.
http://www.ogracing.com/omp-hte-r-xl-racing-seat
http://www.ogracing.com/racetech-rt4...cing-seat-tall
If you have any questions, please give us a call at 800-934-9112 and we will be happy to assist you.
Kind regards,
Kind regards,
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
6'8" makes me think that IF it would work, it would be without the seat pad. The Ergo seems to have a relatively low shoulder harness hole. That is purely subjective though.
I have one that is going into my car currently. Seat fits great. 5'8 170 Medium seat. But I will use it without the cushion. My wife who is 5'4 will use it with the cushion.
YesIfit:
Height(total height) / Width(seat bottom total) / Width(seat bottom inner)
Corbeau FX1 Pro Wide -
952/560/482
Sparco Ergo L -1020/520/370
RaceTech 4009HR WT -910/510/420
OMP HTE-R XL -920/530/415
That makes the Sparco the tallest, but also the narrowest. I'm fairly skinny (36' waist), but no bean pole either (former ball player). I've done extended time in someone else's car that had an old Sparco Pro 2000 in it, and while it was much shorter, it didn't seem to pull down on me too bad and make the shoulders sore. However, it was too narrow and my stints went something like this:30 minutes in - "This seat is a little tight in the hips ... I wish it were a bit wider."
1 hour in - "Ok, this isn't very comfortable."
1.5 hours in - "This is downright miserable."
2 hours in - "Get me the eff out of this car!"
- Ross
