How common is it to re-gear a Cayman S transmissio?
As I continue my search for a Cayman S track car, I haven't noticed any that have been re-geared.
Since I am used to my re-geared 993, it got me wondering - is a Cayman S in need of re-gearing (excepting I suppose the pro race series)?
Rick, you won't find many (if any) re-geared Caymans. In prepared PCA class different ring and pinions can be installed. I had that done this summer but the jury is still out on whether I keep it that way. I know of only one other racer that had this done on their Cayman.
Thanks; the last thing I want to find out is that I should spend $ on re-gearing.
I'd like to share the build specs of the cars I am considering.
Is that ok with you?
would it be easier to leave the gearbox stock and change the final drive?
that said, I know there's a 996 short ratio set out there...but it's not cheap, and whether or not it's a good "speed per dollar" mod is unknown to me.
If your rules allow, you may want to swap your gearbox for an older 5 speed from a Boxster (non-S). Those ratios seem better suited for racing, and this route is much lower cost than changing the ring and pinion ratio on these cars. One guy on 986forums who races in Finland did this, and has won his series two years in a row. Good luck...
The gearbox output shaft is the pinion shaft in the transaxle so not easier to change one or the other. Everything gotta come apart.
I can email you the spec of my car as it has evolved a bit over time. I have spent a lot of money on items that I found to have a marginal benefit (big brake kit) and I was missing some items that I wished I had spent the money on airliner (Motorsport air/oil separator, true oil pressure display, Motorsport coolant temp switch, 3rd radiator).
Rick, of course! I spent a small fortune on this mod and I'm not sure it's actually worth it. Problem is that on some tracks like Pocono and WGI with long straights you will be bouncing off the rev limiter in 6th gear and the ring and pinion are very small so they could easily break if for example you get back on the track after an "off" while spinning your wheels. You clearly have better acceleration and you're always in the right gear.
Thanks; I'll send you a PM with my email. It's always good to learn from the experiences of others.
Rick, sent you an email.
As far I know there are still no gears available for the 987.1 six speed. I have not looked for a while and I could be wrong.
However, you can install the gearbox out of a 986S boxster and rear-gear 3,4,5 through California Motorsports (and/or change the R&P as well).
Cheers,
Cheers,
Just out of monkey curiosity I looked at some of the modern transmissions compared to the g50/30 in my car.
The Caymans look pretty decent stock, all use factory rev limits and tires are 265/40 x18 for the newer cars and 265/35 x18 for my old 993, The Cayman S manual 6 speed loks particularly good stock.
