ABS/PSM error in dash, please help! (boxster s 2004)
i think thats the problem....
this is connected next to the brake sensor pad? Under the little metal clip?
if so, i dont think i have something connected there... im not 100% sure
i dropped the car at the porsche dealership since im in a rush, leaving for the track tomorrow
Brake wear sensor shouldn't fault the entire system. You need to pull codes to see what is actually the issue. If you've pulled a lot of electrical components out then that could easily be your issue. Lots of information comes across from a lot of different modules.
well, so far, i find out that ive removed a little black box in front of the shifter,
this box has something to do with abs and psm... i think i found out my problem
thx everyone for the help, i will report later if its works
That sounds like the combo sensor - yaw rate and lat, usually installed in or around that area (near center/CG of car). Not much will work with that removed, just limited ABS function!
