PCA enduro pit stop, fuel jug recommendations
So I looked around on the forum and could not find any info, but I am looking for recommendations on the type of fuel jug to use during a pit stop.
We have 5 minutes on our pit stops. I want to keep it simple, and I do not plan on removing the stop or stock reducer that limits the size of nozzle, unless there are some go recommendations out there too.
Thank you
Thank you
I'm a fan of the Red head dry break systems... You can dump 5-6 gallons into the car in just seconds..
The scruit Chester suggested this weekend that two 2.5 gal jugs empty way faster than one 5 gallon one does.
Is there more than one kind? I'm using Scribner 5 gal jugs and they work well.... I kind of assumed they are all basically the same..
For the restrictor problem I've seen some complicated solutions (funnels etc) but I just clamped a 4" piece of 1/2" copper pipe in the end of the "hose". 5/8" (the OD of 1/2" pipe) is the same ID as the hose and as a bonus fits nicely in the restrictor orifice.
are these any good?
http://hunsakerusa.com/images/F44276365.jpg
or is the atl fuel jug with the red head dry break system the way to go?
http://ecx.images-amazon.com/images/I/416WWG17YkL.jpg
are these any good?
Dry brake is very nice, but requires modifying the filler neck with the dry brake receiver.
My car does not go thru 3/4 of a tank in a 90 minute enduro...problem?
